FInding Studs On Celings Of Houses - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2009, 02:52 PM   #1
Rewards Points: 152
FInding studs on celings of houses
I want to install a chandellier, but i wanna find the stud on the ceiling to secure the junction box.
I was always curious but i always wanted to know how are the studs spaced apart on the ceilings and also how are the joists spaced apart.
humberguy is offline   Reply With Quote
Old 07-09-2009, 03:18 PM   #2
300zx's Avatar
Post
Stud finder is the best way without going in attic.Most here are 2 ft center to center.Stud Finders are anywhere from $10.00 to $20.00 and up this one is $20.00
300zx is offline   Reply With Quote
Old 07-09-2009, 03:44 PM   #3
MT Stringer's Avatar
Rewards Points: 254
You may have to go into the attick and take a quick look. I was having trouble finding a joist, and a quick peek revealed the joists were running the opposite direction that I had assumed! :-(
You might have to put in a nailer between two joists to mount your box to.
MT Stringer is offline   Reply With Quote
Old 07-09-2009, 04:14 PM   #4
You won't find studs in the ceiling.
You will find joists or trusses every 12,16 or 24" though
A studfinder doesn't know the difference either.
Sometimes you can knuckle knock the drywall and get close.
Look at the outside of the roof and you can generally tell which way the trusses are running. A corner room with a hip roof may have then running both directions
220/221 is offline   Reply With Quote
Old 07-09-2009, 07:51 PM   #5
If you find studs in the ceiling, it means that the house has rolled on its side and its time to flee!
Old 07-10-2009, 03:55 PM   #6
Once you find your "lumber" through the drywall I always get a "poker" (I'm not sure exactly what it's called... it looks like a screwdriver with a sharp point.) Anyway, use it to map out the "lumber" so you're dead on the center. I do this when I install heavy plasma tv's. Once I find the stud I poke holes until I find the edge of the stud... then go the other way until I find the opposite edge. This way you know for sure you're screwing into the center.
(simple putty fills the holes when done)
deeze is offline   Reply With Quote
Old 07-10-2009, 05:28 PM   #7
Originally Posted by 221/222 View Post
You dont know what the fk you are talking about go back to school stud finders will work on ceilings.Use them every day and works every time
I have plastered walls. The plaster board has a foil backing for insulation purposes.
Stud finders don't work worth a on this!
Dry wall, yes! But not this.
My daughters house has drywall installed over plaster on wood lath and it not good there either!
Old 07-10-2009, 05:58 PM   #8
300zx's Avatar
Thumbs down
Old 07-10-2009, 06:27 PM   #9
(RE 221/222) So you joined today just to say that?
What he said - if you can read
is that studs are NOT located in a ceiling
but that a stud finder will work because they don't know the difference either
Old 07-10-2009, 07:31 PM   #10
221/222 Your posts were just trashed this time.
If you keep up that attitude, you will be banned from this site.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-10-2009, 07:32 PM   #11
In case you're interested, its name is an 'awl'.
http://en.wikipedia.org/wiki/Awl
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 09:12 AM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
Finding studs in a lath and plaster wall Oilerz Remodeling 8 03-02-2008 11:52 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
