Finding Replacement Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 03:30 PM   #1
finding replacement motor
I have a century electric motor that just smoked. model RS-224-NC4-41 code E Serial #6AL19464 service factor 1.2 115v 25 amp 1750 rpm I have been trying to locate a replacement but am having no luck with cross references or even finding one similar any help would be appreciated
2much2 is offline   Reply With Quote
Old 09-24-2010, 03:51 PM   #2
No Hacks Allowed!
Although I haven't attempted to look-up the exacts specifics of your Century motor, can you tell us what the motor is used for? Indoor or outside exposed to the elements? Does the motor drive a fan or ??
What type of enclosure and NEMA frame is your old fan motor?
NoHax is offline   Reply With Quote
Old 09-24-2010, 07:59 PM   #3
Rewards Points: 803
try grainger.
TimPa is offline   Reply With Quote
Old 09-25-2010, 06:56 AM   #4
motor use
It is used indoors but the outside temp here in North Dakota fluctuates from 100 in the summer to - 30 to - 50 in the winter. This is for my shop air compressor it was installed many moons ago by the original owners . it was a homemade setup, I believe it was originally a reefer unit motor. Thank you for responding. To the other person, thank you I will try grainger
Old 09-25-2010, 07:01 AM   #5
a little lost
type of enclosure? the motor housing itself?
NEMA? Unfamiliar with that term.
Old 09-25-2010, 07:36 PM   #6
Rewards Points: 492
I've had luck
Just listing a few with easy internet hits:
www.electricmotorwarehouse.com
www.cshincorporated.com
www.emotorpro.com
diyorpay is offline   Reply With Quote
Old 09-26-2010, 12:27 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Very basic all we need to know the Frame size and NEMA or IEC frame size then go with HP figures if stamped and RPM then from there you can able find a replacement motour.
All the details will be on the nameplate so you can not miss it.
Merci.
Marc
Old 09-26-2010, 11:25 AM   #8
Rewards Points: 78
Like French electrician says, we need to know the frame size. The manufacturer knows you need it too. That's why its not listed on the name plate.
It could be a proprietary motor or a standard motor. The only way to know is by the frame measurements. Using the chart provided in the link, measure your motor and find your frame size. You did ask for help after all.
http://www.electricmotorservice.net/nemachart.pdf US NEMA motors only. Google "IEC" Frame sizes for European style motors.
You can also take the motor to a motor shop or somewhere like Grainger like Tim said and they can check it for you.
Friedrich ductless blower motor replacement jon d HVAC 5 11-03-2011 12:27 PM
Questions about finding replacement blower motor revg HVAC 3 02-14-2010 08:39 PM
Heil fan and motor replacement pinkertonpv HVAC 6 12-10-2009 10:10 PM
Suitable replacement motor? randolph1012 HVAC 4 06-24-2009 10:04 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 07:30 PM
