Finding The Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 01:39 PM   #1
finding the circuit
I'm not an electrician, but have rewired our mobile home. I used the old wire for the most part and was able to get everything to work on the correct circuit but for one. Its as if the circuit does not exist. Any suggestions on how to trace the main power source? All sheetrock is done....
tednterry is offline   Reply With Quote
Old 02-09-2012, 01:55 PM   #2
Rewards Points: 2,516
Seems as if you rewired an entire dwelling you should be able to track down a faulty circuit.
But try a Circuit Breaker Tracer for Electrical Systems from 90 to 250A/C Volts with Carrying Case.
Good luck.
hammerlane is offline   Reply With Quote
Old 02-09-2012, 01:56 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Start checking plug boxes in the area of the dead circuit for loose wires.
Any voltage reading at all?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-09-2012, 02:32 PM   #4
Everything else works. No shorts or tripped breakers
Old 02-09-2012, 02:32 PM   #5
Yes, one would think
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 10:04 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
