Finally Got Around To That Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 07:24 AM   #1
Rewards Points: 39
Finally got around to that breaker
Went in there to change one to afci and found this.
Is this corrosion? And why is it only one? I know most of the house breakers are on the right, but it never feels warm or hums. I really hope this isn't going to be a another problem to have to get fixed. Here's a large pic of the entire panel if anyone wanted to look it over. It's a GE panel with all GE breakers except the one for the AC. It's a Siemen breaker for some reason.
http://img11.imageshack.us/img11/5716/largeca.jpg
Sliding Man is offline   Reply With Quote
Old 12-19-2011, 07:34 AM   #2
Electrical Contractor
kbsparky's Avatar
It looks like you have a bad connection at the main breaker. Probably internal to the main breaker itself.
OR a bad bus bar connection where the main bus bar attaches to the extender bar up to the main.
You might want to remove those breakers to examine for loose/bad connection(s) on the bus.
In a case like this, I'd opt for changing the whole guts of the panel.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Sliding Man (12-19-2011)
Old 12-19-2011, 05:36 PM   #3
Rewards Points: 39
Thanks. So many issues with this house.
Tags
100 amp , corrosion , oxidization , rust
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 07:49 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
