Final Electrical Inspection Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 05:21 PM   #1
final electrical inspection question
I'm getting ready for a final electrical inspection. I am putting in potlights but will not have the drywall done by inspection time. Must I install bulb holders for example in place of each potlight or would the inspector be satisfied with having them left open?
Also I have one junction box that I added an extension to increase the capacity. I have 7 cables( #14 wire) in the box. Is that too many. There appears to be lots of room for them all. Thanks for your help.
Ps I live in Ontario Canada.
beech is offline   Reply With Quote
Old 05-22-2011, 09:29 AM   #2
Licensed electrician
Rewards Points: 1,770
Where you you not using new work recessed and installing them now?
Old 05-22-2011, 03:23 PM   #3
Don't have the drywall up so can't install them yet.
Old 05-22-2011, 04:01 PM   #4
joed's Avatar
Rewards Points: 13,338
New fixtures go up before the drywall.
Old 05-22-2011, 07:41 PM   #5
Thanks. I have the kind of fixtures that are for a retrofit and i wanted to use them on this project.
Old 05-22-2011, 07:51 PM   #6
IBEW Electrician
seems to be more a hassle using remodels than new construction... but any way im assuming your going have switch legs waiting for them in the ceiling and the inspector is going to ask why you have loose wires in your ceiling, which do not fly for inspections.... and 7- 14's is fine in the junction box you actually didnt even need the extension ring if its a 4x4 box
Scott3229 is offline   Reply With Quote
Old 05-22-2011, 08:10 PM   #7
Journeyman Wireman
Rewards Points: 150
If the drywall isn't up, you aren't ready for a final inspection.
Jupe Blue is offline   Reply With Quote
Old 05-23-2011, 07:32 AM   #8
I'm just talking about the final electrical inspection. No drywall is needed for that.
Old 05-23-2011, 07:35 AM   #9
joed's Avatar
No drywall is usually the rough inspection.
The final inspection is after the job is complete and all devices and face plates etc. are installed.
Old 05-23-2011, 08:26 AM   #10
Electromagician
Oooooooohhhh!
powerfactor is offline   Reply With Quote
Electrical Issues with home inspection Homebuyer12 Electrical 15 11-18-2010 04:34 AM
First time home buyer with question about results of home inspection. autumnredstorm Off Topic 3 09-18-2010 09:47 AM
Old Electrical Box Insurance Question bailey35 Electrical 4 06-29-2010 01:58 PM
Important Wire Nut and Electrical Tape Question Wolfies167 Electrical 22 01-06-2010 12:59 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
