Filling In Conduit
Spray foam will work. You will have to dig down to pull out the old concrete and cut the conduit anyways, when it comes time to fix. I would just put a garbage can over it, or just leave. You can always use a shop vac to pull the water out, which if you just cap with spray foam by putting a small plug into the conduit, you will be safe.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
