Fill Question For Generator Inlet - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 05:23 PM   #1
Rewards Points: 332
Fill question for generator inlet
I am installing a 50A generator inlet and plan to use PVC conduit and 6ga THWN for the 2 hots and neutral. Should I also use 6ga for the ground?
Also, what size conduit should I use to be in compliance with fill requirements?
Thanks.
sgip2000 is offline   Reply With Quote
Old 01-04-2013, 05:58 PM   #2
Rewards Points: 320
#10 copper is okay for the ground. The minimum size pvc is 3/4 but unless it is a very short run I would use 1" as the minimum.
teamo is offline   Reply With Quote
The Following User Says Thank You to teamo For This Useful Post:
sgip2000 (01-04-2013)
Old 01-04-2013, 06:24 PM   #3
Rewards Points: 332
Thank you for the response.
The run is about 3ft. I have 3/4" and 1" PVC so I'll likely use the 1" anyway. Just wasn't sure if I needed to go larger due to the wire gauge.
Old 01-04-2013, 08:41 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Thanks.
Short and sweet answer for the grounded conductor you will only need #10 and for the PVC conduit 3/4 inch is the smallest size it will be allow with that combation you posted.
And there is one tip if you used the weather proof box either metal or plastic verison drill a small hole on the bottom of the box so the water can drain out and make sure you pitch the pipe down if possible if run in horztonal.
Merci,
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
NJMarine (01-05-2013), sgip2000 (01-04-2013)
Old 01-04-2013, 09:53 PM   #5
Rewards Points: 332
Thanks for the responses. Your answers have confirmed my plan.
This is the inlet I purchased. There is a small drain hole at the bottom already.
http://www.homedepot.com/webapp/wcs/...68&R=202554868
For the anti interlock crowd, I also purchased the SquareD OEM interlock kit for my panel and it is UL listed and compliant.
Calculating fill volume question toobhed Electrical 4 08-21-2011 05:31 PM
Eljer toilet circa 1996 question noone Plumbing 0 08-02-2011 09:27 AM
Oil tank fill and vent question Davidb6 HVAC 4 01-30-2009 07:44 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
