Old 03-30-2008, 11:28 PM   #1
Fill plates for circuit box?
I have some unused breaker in the panel and like to take them out and cover it with fill plates. It is SquareD QO panel but the ones I found for them seems narrower. Even their own. It might be due to older panel.
What is the other solutions I have or are there universal ones that I can find?
Thanks.
ptcamaro is offline   Reply With Quote
Old 03-31-2008, 09:36 PM   #2
Union Electrician
goose134's Avatar
Are you saying that the insert is too narrow for the opening? Or too short to bridge the gap that is the length of the breaker? If it is too narrow, try another kind, perhaps a Homeline blank. Those breakers are wider than QO and may help to fill the gap. The length shouldn't be a problem, but if it is, let us know.
Also, I'm sure you know this but a two pole breaker requires two blanks.
goose134 is offline   Reply With Quote
Old 03-31-2008, 09:55 PM   #3
Floor Sweeper
I think I know exactly what he is talking about. I also found that the new QO filler blanks are not as long as the slot is wide in the older panels. The tabs on the blanks do not keep the blanks from falling out.
The HOM and QO blanks are the same length.
junkcollector is offline   Reply With Quote
Old 03-31-2008, 10:32 PM   #4
Exactly, they are short. It is good for the main which has slightly shorter openings.
There has to be another solution to this. Any? What can I do to close?
Thanks.
Old 04-01-2008, 09:18 AM   #5
Licensed Pro
Just leave the breakers in the panel and label them as "spare".
Old 04-01-2008, 03:46 PM   #6
Uhhhhh.....why?
I'd much rather have a breaker securely in place than blanks that fall out when you take the cover off. I HATE panel blanks.
220/221 is offline   Reply With Quote
Old 04-01-2008, 03:53 PM   #7
Sounds like another amazing use for....
perpetual98 is offline   Reply With Quote
Old 04-01-2008, 09:37 PM   #8
No , I would not do that. not with electrick.
Leaving the brakers in and labeling them blank sounds good in this case.
Old 04-02-2008, 09:12 AM   #9
It was my April Fools joke of the day.
Old 04-02-2008, 02:12 PM   #10
Licensed Electrician
jrclen's Avatar
Not to nitpick, but label them spare. That is a universal electrical term understood by the next guy who looks. Leaving them in is a good idea.
jrclen is offline   Reply With Quote
sheetrock mud...how big a gap will it fill? analogmusicman Building & Construction 2 02-23-2008 08:53 PM
Gaps in drywall. What to use to fill them in. yummy mummy Building & Construction 13 01-02-2008 01:19 PM
