Feeding Romex Down Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2015, 08:19 AM   #1
Rewards Points: 874
Feeding Romex down wall
Trying to fish this down the wall from a switchbox to a hole in the wall. It's only about 3 feet but the insulation in the wall is making it very difficult. Any help on how I can get through this? I really can't deviate from the line I'm taking. Thanks
Mstrlucky74 is offline   Reply With Quote
Old 06-06-2015, 08:32 AM   #2
An electricians fish tape should solve the problem unless it's foam insulation
jimn01 is offline   Reply With Quote
Old 06-06-2015, 09:16 AM   #3
Rewards Points: 874
I'm using one.
Old 06-06-2015, 09:36 AM   #4
Rewards Points: 366
Are you getting tangled on the insulation or do you think you are hitting some other internal obstruction?
jreagan is offline   Reply With Quote
Old 06-06-2015, 09:45 AM   #5
Rewards Points: 178
A fiberglass fish rod would work better if it is a straight shot. Or cut the end of the tape and stab it through the insulation.
AfterShockews is offline   Reply With Quote
Old 06-06-2015, 10:01 AM   #6
Rewards Points: 3,396
use the metal..
go to the back wall...front wall.....side to stud.......through insulation....??
some times it takes seconds, other times amazingly, the one that looks the simplest takes forever....... I think it's based on how jupiter is aligned with mars..not sure........
deep breath......walk away......come back to it... persistence
ritelec is offline   Reply With Quote
The Following User Says Thank You to ritelec For This Useful Post:
supers05 (06-06-2015)
Old 06-06-2015, 10:06 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,180
If you are fishing down with the switch box in place, remove it, fish the cable and install a new box.
Coastal South Carolina
Old 06-06-2015, 10:12 AM   #8
Snaking......sometimes (alot) you need to work two.........with a hook in it trying to catch one another (careful not to get caught with hook or hook cutting into another wire)...
sometimes a short piece.........sometimes a longer piece that will reach where the other one is in case you need to pull that one through.......
sometimes you catch the two together and have to connect your wire to the back end of one of one of the fishtapes (I call it snake) to pull it ...
Old 06-06-2015, 10:25 AM   #9
Rewards Points: 874
Tangled in the insulation. It seems to blocking it from pushing through. Thx
Old 06-06-2015, 10:26 AM   #10
Rewards Points: 874
no box is removed. You would think it would fish down fairly easy.
Old 06-06-2015, 10:28 AM   #11
are you using the big bulbes head that comes with the snake?
if so, you may need to cut it off........ and tightly bend the snake to make a hook.................
(don't go through the insulation............slide it down the wall or studd)
Old 06-06-2015, 11:07 AM   #12
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,418
Are you sure you are not stuck behind a plastic vapor barrier... or fire blocking.
And a "fish stick" should definetly pierce fiberglass insullation...even if someone just crammed/packed that insulation in.
Keep trying different areas of the insulation and against the frameing.
And take some black tape to make a smooth sharp end on your fish tape if the end is ragged at all.
MTN REMODEL LLC is offline   Reply With Quote
Old 06-06-2015, 12:07 PM   #13
Rewards Points: 874
Thanks...been trying everything for the last hour and a half....ugh..fu$&!! lol thx
Old 06-06-2015, 12:33 PM   #14
Rewards Points: 46
Tried fishing up? Just thinking outside the box
Cheers!
supers05 is offline   Reply With Quote
Old 06-06-2015, 12:58 PM   #15
Rewards Points: 874
Cheers!
Tried....thx
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 10:32 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Can I run romex across garage wall? heyd Electrical 2 08-25-2010 09:21 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
