Feeding Power To Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 08-23-2010, 07:35 PM   #1
feeding power to garage
I want to power up my garage and have some questions I hope someone can help me with. would like to run the
1. I would like to run the feed out of my cottage and run it in a conduit alongside the cottage about 2 or 3 feet above ground level. Is that OK
2. I will then run the feed again through a conduit into the ground to a depth of about 2 feet. Then run the cable (U rated) without a conduit 2 feet deep up to the garage. Then pull the cable through a conduit up to the side of the garage and into the panel.
3. I only need 3 circuits in the garage so am thinking that a 40 amp breaker should suffice.
4. Due to cost I thought I would run aluminum wire. What gauge would I need for this 4 amp circuit and is aluminum OK for this application..
5. Finally can I attach the aluminum wire to normal breakers that would normally have copper wire as long as I put that wire treatment on them.
THanks for all your help. If there is anything I forgot that you notice please let me know. Again thanks and man this is a great site.
beech is offline   Reply With Quote
Old 08-23-2010, 08:29 PM   #2
Where are you located ?
Distance to the garage/ total length of wire needed ?
I would run conduit all the way
Old 08-23-2010, 08:58 PM   #3
Im in ontario canada. garage is approx 20 feet from cottage . Total length of wire would be approx. 50 feet. Thanks
power to "half" the house dogvila Electrical 8 07-13-2010 10:04 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 03:51 PM
