Feeding The First Receptacle From Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 10:50 AM   #1
Feeding the First Receptacle from Service Panel
I'm building a detached garage. The new Service Panel will be laid between studs.
I want to run 1/2" EMT horizontally to the first receptacle. What kind of EMT connector [EMT to SP] will pass inspection? Do I even need a connector? How about just using the connector without the setscrew?
[You can see, I only want to drill a 'minimal clearance' hole through the stud.]
Blackbeered is offline   Reply With Quote
Old 11-24-2011, 11:26 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
Why do you need EMT? If you the walls will be covered with drywall, then you can run Romex. You only need to use EMT when the wires would be exposed and subject to damage.
If you were not planning on putting on drywall, I would highly suggest rethinking that idea. The reduction in dirt and dust alone is worth doing drywall.
ddawg16 is online now   Reply With Quote
Old 11-24-2011, 11:41 AM   #3
Rewards Points: 126
This is a set screw EMT connector. One on each end.
Old 11-24-2011, 12:42 PM   #4
JV,
It's that pesky little set screw I'm trying to avoid. [And If I leave the set screw off, even though the conduit isn't going to be moving side-to-side, I'm not sure I haven't compromised ground continuity by letting the conduit 'flop around' in it.]
Let's say I'm coming out of the left side of the SP ... thru a knockout and a 3/4" hole thru the stud. I was wondering if there's an EMT "barb" or other code-approved connector that'll allow me to slip in the conduit rather than the type you show.
Old 11-24-2011, 02:04 PM   #5
Sparky
Rewards Points: 510
this is a 'compression' EMT connector. more expensive but should fit in a smaller area. although the set screw doesnt protrude very far past the connector anyway
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
Blackbeered (11-24-2011)
Old 11-24-2011, 02:30 PM   #6
Thanks Techy
I'm gonna assume that fitting will accept 1/2 rigid conduit [and isn't for watertight flex].
Old 11-24-2011, 05:54 PM   #7
Sparky
Rewards Points: 510
1/2" GRC(rigid) no, but yes it will work for 1/2" EMT
Old 11-24-2011, 09:54 PM   #8
Licensed electrician
Rewards Points: 1,472
Just drill the hole below the panel and bend a 90 on the conduit.
Old 11-25-2011, 06:24 AM   #9
Thanks for All Those Replies ... So Quickly
... I've got what I need. Please consider "the case closed".
200 amp panel w/100 amp service PirateKatz Electrical 8 12-26-2009 03:42 PM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 07:35 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
main service panel ptcamaro Electrical 9 03-30-2008 09:58 PM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 05:41 AM
