Old 08-15-2012, 03:28 PM   #1
Feeder Cable Question
I'm running a feeder cable 90ft. to my stand alone shed and i'd like to have access to roughly 50amps max. If i run 4/3 aluminum feeder wire, will that be sufficient? I've heard that there is loss with aluminum wire, so i'm just making sure i can actually use this cable.
This is the cable i was thinking of using: http://www.platt.com/platt-electric-...px?zpid=280732
Here is the alternative in copper: http://www.platt.com/platt-electric-...px?zpid=157928
PumpedUpKicks is offline   Reply With Quote
Old 08-15-2012, 04:11 PM   #2
Master Electrician
You can't run quadplex right to the panel. You have to connect it like you see most overhead services. So you would most likely need acouple mast heads and some fusible links to do the job. Cable price is much lower but its going to be a lot more work for you than if you just run an underground pipe and single conductors in it. Some areas homeowners aren't allowed to run it so I would look into that as well.
Nm I didn't check the links. I thought you were talking cable with a messenger line.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-15-2012, 04:31 PM   #3
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
The link you have says 4/0 not #4. Not sure if you just have that for illustrative purposes but, I don't think mobile home feeder cable is available smaller than #2. You may have to go with single strands.
PS. You damn sure don't want to pay $3.66/ft. for 50 amps
wirenut1110 is offline   Reply With Quote
Old 08-15-2012, 07:28 PM   #4
I found a local place that will sell me aluminum 2-2-2-4 wire for $1.67/ft. This basically eliminates my question. I won't have to worry about getting enough amperage with 2 gauge. Apparently like you pointed out, $3.67/ft. was a little high. This place has some killer pricing for things.
Old 08-15-2012, 08:04 PM   #5
Missouri Bound's Avatar
Use this calculator to help you determine feeder sizes. Wire Size Calculator
Do you want it your way or the right way?
Broken feeder cable? Ninjaman Electrical 11 03-10-2012 06:35 PM
Question: Had a short circuit - burned through cable tpagel Electrical 13 10-04-2011 09:53 AM
SubPanel wiring question TexasRedNeck Electrical 11 01-03-2011 09:04 PM
SOOW cable usage question CAD Electrical 10 10-17-2009 12:33 AM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
