Feed Sub Panel From Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 12:29 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
HI,
One more quick question , Is there anything that restricts me from feeding the garage sub panel from a sub panel in the house?
In other words, is there any reason that I have to make a home run to the SE for the feed to the garage or can I feed it off of the sub panel? (the sub panel is a 4 wire feed connected via EMT to the SE).
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-02-2009, 12:42 PM   #2
Rewards Points: 204
Sure, you can feed another sub from the one you have. Same rules. 4 wires. Neutral and grounds seperated. But you already know that.
Old 02-02-2009, 12:48 PM   #3
DIY'er
jamiedolan's Avatar
Great, thanks. I just wanted to make sure there wasn't anything I was missing.
I know there are some special rules that require a run directly to the SE if romex is used in some cases. I didn't think that applied to runs of THHN, but wanted to make sure.
Thanks for the confirmation
Jamie
Old 02-03-2009, 12:22 PM   #4
Rewards Points: 204
I know of no such rules. Additional sub panels are used all the time to extend the capabilities of the existing main or sub panels.
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
200 amp feed thru panel leroy Electrical 4 01-30-2009 12:28 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
