Federal Pioneer: Upgrade 24 Circuit To 32 - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 12:07 PM   #1
Federal Pioneer: Upgrade 24 Circuit to 32
Hey guys,
First post in this forum, but we currently have a 100 AMP 32 Circuit Federal Pioneer Stab-Lok Panel.(CP1024)
It has the exact same dimensions as the 32 Circuit(CP1032). It just looks to have a separate panel cover and is missing the guts to plug additional breakers into.(It just has plastic slots minus the conductor points.
Has anyone had any luck keeping the existing box and just upgrading the guts?
Thanks,
Justin
jkurtenbach is offline   Reply With Quote
Old 10-23-2011, 02:23 PM   #2
Electrician
Rewards Points: 802
If you could buy just the guts(i doubt you can) you probably end up paying just as much if not more then the price with the guts and panel. There the same dimensions because they probably use the same tub for both the 24 space and 32 space panel but with different guts.
Are you running out of room in your panel, is this why you are asking. If so why not install a sub panel.
darren is offline   Reply With Quote
Old 10-23-2011, 08:40 PM   #3
Electrical Contractor
kbsparky's Avatar
If they both use the same enclosure, swapping the guts should be no problem.
-KB
Old 10-23-2011, 10:48 PM   #4
Thanks guys,
I am not particularly worried about the cost of the actual parts. as it is less than $100 for the actual panel. My worry is more around the time involved to pull and re-run the wires.(It has very short leads, so could be tricky to get a new in) My thoughts were the following could basically be done...but I could be wrong:
1) Disconnect Main Service.
2) Pull all breakers(but leave hot wires connected).
3) Run new bus-bars and stab lock connector parts.
4) Disconnect the Neutral Wires from the Neutral Bus Bars and install new ones.
5) Have inspector check work and turn main service back on.
As far as the subpanel, the reasoning for not doing so is as follows:
1) I want to run subpanel to my garage at a late date, and running multiple will make it messy.
2) I don't have the available slots to run a subpanel without relocating some of the existing wiring)
Thanks guys,
Old 10-29-2011, 04:25 PM   #5
Federal Pioneer? Is that Federal Pacifics brother? I haven't heard of that one.
Sine is offline   Reply With Quote
Old 10-29-2011, 04:35 PM   #6
Rewards Points: 2,240
Have you done a "google" search on "Federal" - "Federal Pioneer"?
"Stab-lok"
See what you come up with.
rossfingal
rossfingal is offline   Reply With Quote
Old 10-29-2011, 04:40 PM   #7
"Stab-lok"
rossfingal
Yes, I found it. I've heard of stab-lok. I just though he meant Federal Pacific. I guess it was mostly used in Canada from what I found.
Old 10-29-2011, 04:53 PM   #8
"Sine"
I wish they were only in Canada - not that I would ever wish "misfortune"
on the good people up North.
We've got "Federal" products installed here (Breaker Panels") -
Oh goody!
rossfingal
(They go by a number of names "Pacific", Pioneer" and others)
"Stab-Lok" don't work too good!
Old 10-29-2011, 05:12 PM   #9
Here's something to check out -
http://inspectapedia.com/fpe/fpe.htm
RF
Old 10-29-2011, 05:14 PM   #10
Electrician
Rewards Points: 802
Federal Pacific and Federal Pioneer are two different companies, but they still have the stigma of not wanting to trip on overload.
Federal Pioneer is made by Schenider Electric, which also makes Square D, and just recently they changed there name to stab lock.
Old 10-29-2011, 07:58 PM   #11
joed's Avatar
Rewards Points: 13,740
Schneider Electric actually load center inserts for converting a fusible center to a breaker center.
http://www.schneider-electric.ca/can..._range_id=7252
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 10:37 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
