Federal Pacific Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 03:05 PM   #1
I have heard the Federal Pacific Subpanels in older homes have been known to be a fire hazard. If i bought a house and wanted to put in a new sub panel to rid of the Fed Pacific one, what am I looking at cost wise? Thanks!
cpntpga is offline   Reply With Quote
Old 06-04-2012, 05:17 PM   #2
Rewards Points: 1,294
The best way to find out the cost in your area is to call an electrician. Nobody here can give an accurate estimate over the internet.
danpik is offline   Reply With Quote
Old 06-04-2012, 06:10 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
$1200.00 plus travel.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-05-2012, 02:11 AM   #4
Rewards Points: 264
Of course we can, the cost will be > $0.
To give the OP a bit better estimate, here's ballpark of materials cost from my service upgrade:
Panel ~200
Service Wire ~75
Weather head ~75
Grounding ~ 50
Extending Circuits that didn't reach ~ 50
Permit - $175
Now if your city is like mine, you'll be required to upgrade most of the circuits to AFCI breakers.
AFCI breakers ~ 440
So for materials alone you're looking in the $625 - 1025 range (excluding tax and markup) for a basic, no problems encountered service upgrade with < 10' from the panel to the weather head.
Now without looking at your particular situation, we don't know if you'll be required to get a larger service (many areas now require houses to have 100 amp services).
Will the PoCo drop will need to be replaced due to upsize, not meeting code, or damage? Depending on your PoCo they may eat the cost, or they may charge you.
If you have underground service, can the same conduit be used or does it need to be upsized?
My materials list only had 2 circuits that needed to be extended. We have no idea if you'll have more.
Without looking at your panel, we also don't know if anyone has done something stupid that will need to be cleaned up.
Given all the unknowns, you can see why we don't like to give estimates. That being said, you'll probably end up in the $1k - $10k range.
The best thing you can do is find 3 reputable electricians in your area and get bids from them.
a_lost_shadow is offline   Reply With Quote
Old 06-05-2012, 02:51 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,858
Electures offer might be a bargain, even with travel.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
electures (06-05-2012)
Tags
breaker , federal pacific , sub panel
Professional opinions on Federal Pacific brand Richo Electrical 9 04-08-2011 05:35 PM
Replacing Breakers on a federal pacific Box Aaroncarpet Electrical 19 09-03-2010 03:54 PM
Federal pionner vs federal pacific Red Squirrel Electrical 2 08-30-2009 11:40 AM
Federal Pacific Panel Replacement Question DIYDesign Electrical 5 03-16-2009 12:23 AM
Federal Pacific panel replacement - inspection? dcp143 Electrical 7 05-13-2008 08:52 PM
