Federal Pacific Breakers...fire Hazards - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 07:46 PM   #16
Rewards Points: 506
I pulled the breaker to demonstrate the type. Breaker snaps right back in. Don't recall seeing any damage. What are you seeing?
jlmran is offline   Reply With Quote
Old 06-05-2012, 07:49 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There appears that there has been arcing inside the circled area.
The Following User Says Thank You to k_buz For This Useful Post:
gregzoll (06-05-2012)
Old 06-05-2012, 07:57 PM   #18
Rewards Points: 6,652
The best thing is for the OP to pull all the breakers, take a front shot to show the whole panel, vs. a corner shot.
Old 06-05-2012, 08:59 PM   #19
Rewards Points: 506
Does that really matter if the FP panels are such a fire hazard? Right now the house is empty and unfurnished, so disconnecting power to the panel would be without problems.
Assuming the bus is ok...Is there a good reason NOT to replace the panel?
Old 06-05-2012, 09:00 PM   #20
k_buz's Avatar
Nope, if you have the money then it would be a good decision.
Old 06-05-2012, 10:38 PM   #21
Rewards Points: 506
This panel is located in a bedroom closet. Thus if I replace it, am I required to relocate it (according to NEC)?
Old 06-05-2012, 10:42 PM   #22
k_buz's Avatar
Yes, panels aren't allowed in closets. Is it possible to turn it around so its facing out the other side of the wall?
Old 06-05-2012, 10:42 PM   #23
Rewards Points: 506
Exterior wall.
Old 06-05-2012, 10:47 PM   #24
k_buz's Avatar
I wish I could give you some other options, but without knowing the layout, I would just be guessing. Remove/move the closet? Might be something to think about.
Old 06-05-2012, 11:07 PM   #25
Rewards Points: 506
I'll probably relocate to garage with new overhead service. Transformer, meter and disconnect are on a pole about 300 ft from house (rural setting).
Is there any NEC prohibition of using the FP panel as a junction box (minus the bus and breakers). This would prevent relocating all the circuit conductors to the new panel...just simply run new conductors from new panel to old panel (junction). Would require lots of wire nuts, but still easier...maybe.
Old 06-05-2012, 11:26 PM   #26
k_buz's Avatar
That is the common way it is done. Remove all the parts, then screw the cover shut.
plywood on fire rated wall acerunner Building & Construction 9 11-18-2016 06:15 PM
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Electrical Fire seansy59 Electrical 1 10-24-2011 05:57 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
Federal Pacific panel replacement - inspection? dcp143 Electrical 7 05-13-2008 07:52 PM
