Federal Pacific Breakers...fire Hazards - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 04:25 PM   #1
biggles's Avatar
Federal Pacific Breakers...fire hazards
over 2000 fire related to the panel an the loads going thru them where the wire insulation melts up and thru the walls to the loads before the breaker trips rated amps... DO NOT BUY OR SIGN OFF ON A HOME WITH THEM
The Following User Says Thank You to biggles For This Useful Post:
operagost (05-01-2012)
Old 05-01-2012, 06:29 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
More info on You Tube
Here is a video:
http://www.youtube.com/watch?v=MkVMC...eature=related
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-01-2012, 06:54 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Where have you been?
This is OLD news.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (05-01-2012), HIVOLT (05-02-2012)
Old 05-01-2012, 08:29 PM   #4
biggles's Avatar
when did it first come out heard it on NBC news tonight about the 2000 house fires
Old 05-01-2012, 08:59 PM   #5
Rewards Points: 6,652
That is your problem. News agencies are right now late on reporting stuff that has been out in the grapevine for weeks, or they are digging stuff up, because the action in Afghanistan is boring, along with the job outlook, so they have to find some other way to strike fear into people.
If it was not for the idiots in D.C. and news organizations, people would actually have some form of common sense these days. Please don't help them along Biggles.
Even the Nato summit this May in Chicago is becoming a real "snooze" fest for the news outlets, so they are starting to feed ignorance by making stuff up. Same with the Olympics in London.
Old 05-01-2012, 09:09 PM   #6
Rewards Points: 264
This news is older than I am.
According to http://inspectapedia.com/fpe/FPE_History.htm, it appears that UL started revoking FPE listings in 1980.
a_lost_shadow is offline   Reply With Quote
The Following User Says Thank You to a_lost_shadow For This Useful Post:
jbfan (05-01-2012)
Old 05-02-2012, 04:30 AM   #7
Ravenworks's Avatar
Then you have the guy on Craigslist trying to off the 10 panels he has from dumpster diving.
Ravenworks is offline   Reply With Quote
Old 05-02-2012, 06:27 AM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
FPE panels...the Pintos of the electrical world.
The Following User Says Thank You to k_buz For This Useful Post:
HIVOLT (05-02-2012)
Old 05-02-2012, 08:09 AM   #9
Rewards Points: 13,690
There's several other companys with recalls on breaker.
A simple Google seach on what you have now should come up with something.
http://plusoneinspection.com/Seattle-recall.asp
Old 05-02-2012, 02:42 PM   #10
Rewards Points: 150
May 1st is the start of rating period (the sweeps). All that counts now is sensationalism, not how current or helpful the story is.
goosebarry is offline   Reply With Quote
Old 05-02-2012, 09:04 PM   #11
Just a DIY guy
Maybe you will see a story on Zinsco panels next.
M3 Pete is offline   Reply With Quote
Old 06-05-2012, 07:36 PM   #12
Rewards Points: 506
So...I just bought a house with this in it. I assume it is the general consensus to replace it?
jlmran is offline   Reply With Quote
Old 06-05-2012, 07:39 PM   #13
k_buz's Avatar
Normally, I would suggest to replace as time and money allows, but since your bussbar is damaged, I would say that it changes the time frame to ASAP.
And in the time being, move that breaker to another position in the panel.
Old 06-05-2012, 07:42 PM   #14
Rewards Points: 506
How do you conclude the bus is damaged?
Old 06-05-2012, 07:44 PM   #15
k_buz's Avatar
I can see it in your last picture.
plywood on fire rated wall acerunner Building & Construction 9 11-18-2016 06:15 PM
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Electrical Fire seansy59 Electrical 1 10-24-2011 05:57 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
Federal Pacific panel replacement - inspection? dcp143 Electrical 7 05-13-2008 07:52 PM
