Faulty Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 01:18 PM   #1
Faulty Circuit
The circuit to one of our bedrooms is not receiving any power. I have already troubleshot this in the following ways:
1. Breaker has been checked and is working properly
2. I pulled the neutral wire from the bar for this circuit - cleaned and replaced it.
3. I pulled and checked every receptical in the bedroom and any that may possibly be feeding the bedroom - no power
4. I checked all GFI recepticals and all are working
5. I turned bedroom breaker off and checked to see if any other nearby outlets were on this circuit - no luck!
It should be noted that each of the above were double and triple checked - I'm hoping to receive an idea I may have overlooked - it's driving me crazy!
I'm at a loss - any suggestions where I might go from here would be greatly appreciated. Thanks, Mike
MCalandra is offline   Reply With Quote
Old 09-08-2011, 01:35 PM   #2
Experienced
Jackofall1's Avatar
Hello Mike and welcome the best darn DIY'r site on the web.
Did you check to see if you had power right at the breaker?
If you do have power there then you must have an open circuit somewhere between the breaker the recepticles.
If you don't have power at the breaker then your breaker needs to replaced.
Mark
Old 09-08-2011, 01:36 PM   #3
Code05's Avatar
Rewards Points: 1,104
Did you use a meter and verify voltage?
Any back stabbed receptacles or bad connections? Easy to miss one.
Code05 is offline   Reply With Quote
Old 09-08-2011, 01:37 PM   #4
Rewards Points: 256
How was the breaker checked and proven to be working properly?
Find the first junction box in the circuit: is there power there?
michaelcherr is offline   Reply With Quote
Old 09-08-2011, 09:22 PM   #5
Mark
Hello Mark
I do have power at the breaker and also switched the power lead to another working breaker just to be sure.
I've checked and rechecked every receptical on the circuit and not a one shows any sign of power.
Old 09-08-2011, 09:29 PM   #6
If I have no power how can I verify voltage?
Old 09-08-2011, 11:18 PM   #7
Thadius856's Avatar
Rewards Points: 504
It's a silly question, but did the circuit previously have power? You didn't specify whether it has ever worked or not.
If you have a non-contact voltage detector, you might have some luck tracing its path away from the panel. A cable toner would be ideal for locating the problem.
I wouldn't leave the breaker on when not testing, as you may have a break somewhere you can't see it. I personally found a cut, live piece of romex laying in a pile of attic insulation.
Thadius856 is offline   Reply With Quote
Old 09-09-2011, 12:28 PM   #8
011010100110111101100101
Rewards Points: 160
I've broken the hot leg under a wire nut a few times. Circuit didn't power a 110v device, but would show very very small voltage with a meter.
The way I learned to twist conductors under wire nuts in the mid '90s seems to be destroying 12awg NM-B these days...
This is pretty straight forward to troubleshoot. But you need to figure out if your grounded (neutral) or hot is dead. A meter, and knowing the cable route will help.
-- Joe
anesthes is offline   Reply With Quote
Old 09-09-2011, 12:30 PM   #9
Rewards Points: 160
Found one in a roof soffit two weeks ago. beep beep beep ARGH!!!!
-- Joe
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 09:04 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
