Faulty Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 12:21 AM   #1
bpm
Rewards Points: 29
Faulty Breaker?
I have a 20 amp breaker that tripped and won't reset. I suspect it's a bad breaker but wanted to hear some ideas/opinions/confirmation. I tried to reset the breaker and it immediately tripped again. When trying to reset it, it actually felt like the switch wasn't moving properly. I removed the black wire from the breaker and tried to reset it again and still no go. The switch is just sort of in the middle in the tripped position. If I push it either to the off or on position it just returns to the middle.
Here's what I think is the strange part. If I test the voltage with my multi-meter I'm getting 3 volts on the breaker terminal, when measured accross the neutral bus. Is this normal? All the other breakers seem to be working fine but one adjacent breaker also seems to show 3 volts even when turned off. Otherwise, everything in the house is working fine and I've been randomly measuring voltage at various outlets and get steady 120 readings everywhere.
My initial hunch is faulty breaker but any thoughts are welcome and appreciated.
Additional informaiton if it's helfpul - the panel is a Square D QO Load Center, probably installed sometime around 1970. Several breakers have been replaced, but the breaker in question is probably original.
bpm is offline   Reply With Quote
Old 08-09-2011, 01:02 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Replace the breaker.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-09-2011, 01:07 AM   #3
bpm
Rewards Points: 29
Thanks for quick reply. One other quick question. When measuring voltage on all the remaining breakers, I noticed that one leg of the panel is at about 120 to 120.5 volts and other tends to be at about 121.5. Is this 1 to 1.5 volt difference across the legs significant, or is that normal. It doesn't seem to be influenced by what is turned on and/or running at the time. Thanks!
Old 08-09-2011, 07:04 AM   #4
Lic Elect/Inspector/CPO
That voltage differance is acceptable.
NJMarine is offline   Reply With Quote
Old 08-09-2011, 07:17 AM   #5
bpm
Rewards Points: 29
Thanks for the help!
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
GFCI breaker trips randomly BimmerRacer Electrical 40 09-21-2009 03:11 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 12:18 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
