Faulty 3-Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2008, 11:19 AM   #1
prc
Faulty 3-Way Switch
The 3-way switches for my kitchen lights are not working properly. My house is 10 years old and they have worked fine until the last couple of days. Now, sometimes when you use one of the switches to turn the lights on, they don't go on. You need to flick the switch off and on to get them to work. This has happened several times, with both switches. Does this mean that one of the 3-way switches is faulty? If so, how do I tell which one?
Thanks.
prc is offline   Reply With Quote
Old 01-08-2008, 12:03 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
Replace both of them. This saves you the guessing game.
1 trip to the store, both switches in hand.
Old 01-08-2008, 12:17 PM   #3
What he said ^
AND.....label the "common" wire and put it on the correct terminal so you are not back here tomorrow with a "How do I wire a 3way switch" post.
220/221 is offline   Reply With Quote
Old 01-08-2008, 04:20 PM   #4
prc
Thanks -- I'll replace both of them.
Old 01-08-2008, 04:50 PM   #5
joed's Avatar
Rewards Points: 11,998
Replace one switch then test it. It is easier to troubleshoot one switch then two.
Make sure identify the common wire. Don't move the wires base on postion. Upper right on one brand of switch will be the same as upper right on a different brand.
Old 01-08-2008, 04:58 PM   #6
Electrician philosopher
What 220 and JB said.
Andy in ATL is offline   Reply With Quote
Old 01-08-2008, 06:58 PM   #7
prc
Thanks -- I was planning on doing that.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
3 way switch help imintrouble Electrical 8 12-13-2007 03:54 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
