Old 08-09-2011, 01:59 AM   #1
Faulty 14-3 Wire
Currently installing a two 3-way switches in my unfinished bedroom in the basement. I have power (14-2) going to box (switch #1) and (14-3) between switch #1 and switch #2 and 14-2 wire going from switch #2 to the light fixture. after connecting the two black wires (14-2 power/ 14-3) in switch box #1 every single wire in 14-3 (black,red,white,ground) is hot. I assume that there must be disruption in the wire (14-3) somewhere and all the copper is touching????? Please help??
jepartri is offline   Reply With Quote
Old 08-09-2011, 02:21 AM   #2
Jack of All Trades
Faulty 14-3 Wire
I'm sure someone else more knowledgable will respond soon. But do you have any staples or cable clamps that are pinching too tightly? It would have to be a pretty bad pinch to make all 4 conductors contact eachother, maybe snagged on a sharp piece of metal somewhere? I recently rewired my garage and I had endless problems with conductors touching, found out I had tightened many of my cable clamps too hard and it'd squished the insulation off the lines inside the sheathing.
I've never wired a 3-way so I can't be much help on whether it's wired right.
DoctorWho is offline   Reply With Quote
Old 08-09-2011, 06:52 AM   #3
Faulty 14-3 Wire
Be sure that the bare wire is not touching switch terminals (except the green screws) or other wires.
Unscrew the light bulb.
Are all of the wires still hot?
By the way, after the neutral (white) and ground (bare or green) wires are correctly hooked up, they cannot register live; the breaker will trip instead.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 08-09-2011, 07:48 AM   #4
Master Electrician
Faulty 14-3 Wire
At switch #1:
Wire nut white power wire to the white wire of the 14/3.
Connect black power wire to the common screw of the switch.
Connect red and black of 14/3 to the other two switch screws.
At switch #2:
Wire nut the white wire of the 14/3 to the white wire of the fixture cable.
Connect the black wire of the fixture cable to the common screw of the switch.
Connect the red and black of the 14/3 to the remaining screws of the switch.
brric is offline   Reply With Quote
Old 08-09-2011, 08:49 AM   #5
joed's Avatar
Faulty 14-3 Wire
What are you using to measure the voltage? If you are using a digital meter is is likely phantom voltage. That is voltage induced by capacitive coupling from the wires being beside each other. Put a load on the other end and the voltage will go away.
Do not PM with questions that can be asked in a forum. I will not respond.
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
