Old 08-26-2011, 08:42 AM   #1
Fastening Romex between 2x4 and basement wall
Hi. So I'm finishing a basement and the new framing is about 3 inches off the basement foundation wall. I'd like to avoid drilling our the studs and run the romex behind, but then how do I fasten it neatly? Any suggestions? Thanks, Dino
DinoT is offline   Reply With Quote
Old 08-26-2011, 08:53 AM   #2
Licensed electrician
Staple to the back sides of the studs.
DinoT (08-26-2011)
Old 08-26-2011, 09:09 AM   #3
Master Electrician
Drilling would be my preference. You could also use cable ties.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
DinoT (08-26-2011)
Old 08-26-2011, 09:25 AM   #4
Code05's Avatar
Duct tape......
Code05 is offline   Reply With Quote
Old 08-26-2011, 10:11 AM   #5
Thanks for the quick responses... I don't have the room to hammer staples behind the studs. I likely will drill, though like the cable ties idea.
Old 08-26-2011, 10:25 AM   #6
Drill every 3rd stud. That will be enough for support.
sjelectricguy is offline   Reply With Quote
