Fast Fluorescent - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 03:17 PM   #1
Rewards Points: 29
Fast Fluorescent
I'm looking for a compact fluorescent light bulb that QUICKLY ramps up to full luminous intensity. The bulb would be used for a front porch light that is now attached to a motion sensor (thanks to replies to my previous post).
I'm currently using a 23W R40 FEIT CFL bulb. When powered on, this bulb will flash brightly for about 1/4 second, then lights very dimly. It takes about 20 seconds to get relatively bright, and about a minute to reach full brightness.
I would prefer a R40 type bulb for this application, but the recessed fixture I'm using could accept just about any size CFL bulb.
My main priority is something that lights and gets bright quickly.
Any suggestions???
fritzycat1 is offline   Reply With Quote
Old 11-23-2008, 03:24 PM   #2
I don't think flourescents in general can handle cold very well. Something about the mercury not vaporizing.
And if your motion sensor has a Triac and not a relay, it may not like powering the electronics for one of these lamps.
Old 11-23-2008, 03:29 PM   #3
Rewards Points: 29
Thanks Yoyizit,
I'm in Southern California, so real 'cold' should not be a problem here. It was probably about 60 degrees last night when I was checking the ramp up time of my CFLs. Maybe not the ideal temperature for CFLs but not real cold either.
Old 11-23-2008, 03:45 PM   #4
Originally Posted by fritzycat1 View Post
Thanks Yoyizit,
I think we had 20F last night.
Try it in other, indoor sockets?
Except for the bright flash, that's the same way my CFLs behave.
Old 11-23-2008, 04:10 PM   #5
Rewards Points: 29
I've got the same lights indoors too. Same result even on warm evenings.
Old 11-23-2008, 08:08 PM   #6
Possibly you could try LEDs but the light they throw off is directional.
Old 11-24-2008, 12:23 AM   #7
Rewards Points: 29
LEDs? That would be cool, but they're still far too expensive.
Anyone else out there have CFLs that brighten up quickly? They've got to be out there somewhere!
Old 11-24-2008, 02:04 AM   #8
Rewards Points: 506
Send a message via AIM to theatretch85
Any suggestions???
I'd say if you need something to get bright quickly, just use an incandescent bulb. It will probably be your best option in this situation, other than using LED's (which you already stated are too expensive for ya).
Personally I hate using fluorescents; they have no place being in the living space of a house, but in my opinion are "OK" for like a workshop or garage. Problem is I live in a cold climate so the garage florescents have to be the "cold start" fixtures which are usually a little more expensive to buy.
theatretch85 is offline   Reply With Quote
Old 11-24-2008, 08:21 AM   #9
DIYer
CFs ramp up slowly, but standard ballasted fluorescents with a quick start ballast come up pretty quickly. They make the old-school "circle tube" style that can fit into some regular screw fixtures.
http://www.wellmax.cn/products_info....o&id=158&lei=2
This might do what you need.
Gigs is offline   Reply With Quote
Incandescent and fluorescent together Big Bill Electrical 6 11-01-2008 06:49 PM
Replacing fluorescent with recessed..thoughts darlenep Remodeling 12 08-15-2008 12:38 AM
Fluorescent lamp flickering Ash Electrical 11 08-03-2008 08:35 PM
Recessed Fluorescent Lighting - how many bakerhouse Remodeling 2 05-13-2008 11:42 PM
Compact Fluorescent Lighting? kcrossley2 Electrical 2 07-23-2007 11:18 PM
