Fart Fan Speed - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 09:35 AM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Fart fan speed
Turned on the fart fan in the downstairs bathroom this morning, and all of the sudden it throttled down in speed about 50%.
The switch is not a dimmer (I don't know if that would work anyway) and it's not making any nasty vibrating noises.
Could it just be on it's last leg or is there something wrong with the wiring?
Journeyman Plumber
Old 02-17-2012, 10:18 AM   #2
joed's Avatar
Rewards Points: 13,338
Oil the motor and clean the fan. It might keep it going for quite a while
Old 02-17-2012, 11:16 AM   #3
Look for other symptoms in the house, it may be a bad neutral.
If the fan current draw has gone up the fan bearings might be bad.
Old 02-17-2012, 11:44 AM   #4
Rewards Points: 14,010
Where does it vent out to?
Just a guess if none of the other suggestions work but, a gust of wind blowing into vent from out side could change the speed on one of those small fans.
Old 02-17-2012, 11:50 AM   #5
rditz's Avatar
take the cover off, then with an extension cord, unplug the fan from the housing and plug it into the cord. if still slow, it is the fan, if it goes back to normal speed, you have another problem...
rditz is offline   Reply With Quote
Old 02-17-2012, 07:03 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,504
Two options -
1 - check the motor is not gummed up !
Take it apart, clean motor shaft and bearings
and apply some clean fresh oil !
2 - Check the capacitor !
A faulty capacitor can cause fans to run slow .
dmxtothemax is offline   Reply With Quote
Old 02-17-2012, 07:09 PM   #7
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
LOL first time I hear someone call that a fart fan. I kinda had an idea what it would be before I clicked the thread. :P
It could also be that the racket you heard was because it was out of balance, and somehow it rebalanced itself. My old fan would do that, it would be very loud because it was off balance and the blades were grinding themselves, but it would somehow fall back into balance and run fine for a bit and then start making racket again. Though it's very well possible there is a bad neutral somewhere if it's part of a MWBC, but that's not really common in bathrooms as far as I can tell, but it's a possibility.
I would start by taking it apart and cleaning it as best as possible.
Old 02-17-2012, 07:36 PM   #8
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
The one in my apartment did that I cleaned and oiled it and it has worked fine since then.
rrolleston is offline   Reply With Quote
Old 02-17-2012, 08:56 PM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by dmxtothemax View Post
Two options -
Ive never seen a fart fan with a cap,theyre usually just small single speed shaded pole motors
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-17-2012, 08:59 PM   #10
plummen's Avatar
Depending on what style of fan you have a lot of those motors are universal,sometimes you can find a cheap $10-$15 50cfm fan at menards and just use the motor without having to change the whole housing out
Old 02-17-2012, 09:41 PM   #11
rrolleston's Avatar
Ours takes the same type of fan that a fridge uses for air circulation. Actually stole it once to keep our fridge going.
The Following User Says Thank You to rrolleston For This Useful Post:
plummen (02-17-2012)
wiring for two speed Emerson motor PerryupNorth Electrical 2 12-02-2011 10:44 AM
2 speed motor continues to run on slow speed Rob Fayette Electrical 2 11-13-2011 05:34 PM
Broan variable speed motor m0t0rgeo Electrical 1 09-22-2011 01:58 PM
Variable Speed Vs " Multi - Speed " alecmcmahon HVAC 15 04-14-2011 03:06 PM
changing speed of grinder MeanGene Electrical 2 03-19-2011 09:53 AM
