Old 12-07-2012, 07:04 PM   #1
Farm Yard light
Mercury Vapor lamp glass broke so do not know the wattage. Numbers on metal base are: JHMAMJ - 4A80AD. What lamp do I need to replace the broken one?
Bob McKay is offline   Reply With Quote
Old 12-08-2012, 12:09 AM   #2
Farm Yard light
Is there a brand name somewhere on the light fixture ?
Are those quoted numbers on the lamp base ?
Or the fixture ?
dmxtothemax is offline   Reply With Quote
Old 12-08-2012, 01:42 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Farm Yard light
The most common answer will show up in the ballast area if the label or marking is not " erased " or gone and most common dusk to dawn MV verison is typically 175 watts ( USA / Canada side ) however there is one gotcha is that you can get the MV lamp but not the ballast anymore.
So if the ballast is shot then you will go with Metal Halide or Super Compat flourscenct lamp.
Merci,
Marc
Old 12-08-2012, 10:48 AM   #4
Farm Yard light
www.e-conolight.com Buy a 150 watt m.h. wallpack.
bobelectric is offline   Reply With Quote
175 watt mercury vapor yard light Michael Toby Electrical 1 09-16-2012 11:15 PM
Wiring a Shed light & internal power DJDesq Electrical 4 08-12-2012 09:12 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
