Fans Function, On Carrier Furnace/AC - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 09:37 PM   #1
fans function, on Carrier Furnace/AC
Fan quit working properly. What componet controls this function?
lumbos35 is offline   Reply With Quote
Old 07-25-2012, 09:44 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Fan relay....
Old 07-26-2012, 12:13 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Majorty of the time the item will be called fan relay however be aware as most moden and pretty well modern furances with A/C unit there will be a second relay to run the A/C unit and most case it will change fan speed as well ( useally go higher on cooling side ) but basically most common curpit is start capaitor that will useally prevent get the motour start up.
If you hear a buzzing noise when the motour try to start up then you know useally starting capaitor is shot but turn the power off first then try to turn the fan wheel by hand it should turn over easy without effort if very hard then pretty much the bearing on the motour is done.
Merci,
Marc
Old 07-26-2012, 01:55 AM   #4
Newer furnaces may have electronic control boards and you might need a schematic wiring diagram. Some of these create their own "electricity" which is more efficient than the electricity from the wall plug. Sort of like how 3 phase motors are more efficient.
Anyway older have relays and are on/off. Newer may have variable speeds and electronic control boards.
Here is a bit on that...
http://www.broanhvac.net/iq-drive-systems-a/263.htm
http://www.innovation-group.com.ua/p...%20Furnace.pdf
Billy_Bob is offline   Reply With Quote
Indoor Coil Cleaning on Carrier Furnace/AC jim97gst HVAC 2 10-21-2011 07:49 PM
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 12:27 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Roof fans sucking air through chimney? Badfish740 HVAC 8 10-08-2008 11:01 AM
