Fan Wiring Help - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2009, 05:28 AM   #1
Help a guy out will ya'?
papabug71's Avatar
Fan wiring help
I didnt know if I should put this here or in the HVAC section, so here goes. Long story short: We had to put in a new central unit this week & the only thing that was worth keeping was the squirl cage fan (blower). The outside unit was hit by lightning last weekend...
Im wanting to put the blower out in my shop. These things move alot of air! Its a Emerson motor, model K55HXJFN-2836. Build date of 03/90. Its 115v-5.9amps & has 3 speeds. I dont know how to wire this thing up to save my life. It has 5 wires.
WHITE: goes from the capacitor to the motor
BROWN: goes from the capacitor to the motor
RED: low speed
BLUE: med. speed
BLACK: high speed
How the heck do I hook this thing up? I just want it on a plug end. I want it on high speed, so I need to run the black wire with what??
Thanks guys, papabug.
P.S. Here are some pics:
papabug71 is offline   Reply With Quote
Old 07-22-2009, 05:35 AM   #2
Electrical Contractor
kbsparky's Avatar
You're missing another white wire. Maybe there was another one connected to the capacitor?
-KB
Old 07-22-2009, 05:55 AM   #3
papabug71's Avatar
I was thinking the same thing. I think the HVAC guys might have yanked it off. Do I need to run another to the capacitor & use it with the black wire? Thats the only way I could see doing it...
Old 07-22-2009, 08:27 AM   #4
biggles's Avatar
loosen the lock down on the squirrel cage and slide the motor out wash the squirrel cage and the sheet metal housing.the motor tag should have the wiring diagram showing a white and black(115v feed) wires going into the capacitor and catching a color speed wire.that thing will blast some air might consider a 3 speed selector switch run the black wire to it and feed the 3 colors up to the switch
Old 07-22-2009, 12:20 PM   #5
Rewards Points: 58
Check the motor nameplate (shown in the pic). There should be a wiring diagram on it.
Old 07-22-2009, 03:31 PM   #6
papabug71's Avatar
Ok, thanks guys. I was going to clean it up anyway. Its kinda filthy. I'll look for a wiring diagram in the process.
thanks,
papabug
Old 07-22-2009, 08:45 PM   #7
Rewards Points: 502
I did something similar as well.
I wired mine to have high/off/low with a toggle switch from Radio Shack.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 07-27-2009, 02:50 AM   #8
papabug71's Avatar
I got it working. Thanks guys.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
