Fan Timer On A Switch Loop - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 02:28 PM   #1
fan timer on a switch loop
Hello all I am new here. I am trying to install a fan timer for the bathroom, but all 4 switches in the box are all wired on switch loops. the attic is above the room so i am able to crawl up there, but I am curious as to the best way to wire it in this situation. I have not been able to find out information on wiring a timer when a switch loop is used. Any advice would be much apreciated.
someguy86 is offline   Reply With Quote
Old 08-02-2010, 03:26 PM   #2
Master Electrician
Rewards Points: 3,870
A mechanical(springwound) timer will work just fine. Electronic timers may require a neutral but I think there are some that do not.
brric is offline   Reply With Quote
Old 08-02-2010, 07:28 PM   #3
Yeah, it would be nice if i was allowed to do that, but i'm not I guess ill have to run the feed to the new switch and then to the fan, I was hoping for an easier fix. Thank you for the idea thow!
Old 08-02-2010, 08:05 PM   #4
Mad Scientist
There are definitely some electronic timers that don't need a neutral, and thus can work on a switchloop. I don't have a link handy, but try a google search for "digital timer no neutral"
McSteve is offline   Reply With Quote
Add new light and switch to a switch loop UncertainSparky Electrical 4 01-24-2010 08:58 AM
Help with 3 way switch loop wylde8 Electrical 7 12-17-2009 05:53 PM
Switch loop detached garage jamiedolan Electrical 2 02-10-2009 07:24 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
switch loop aokss Electrical 13 05-07-2007 08:41 PM
