Old 12-03-2012, 10:48 PM   #1
Fan Speed Control
I'm replacing a Hunter ceiling fan that is pushing 20 years old. No issues with it - just looking to update the style. I'm actually going to reinstall it in a spare bedroom.
The replacement is a Allen & Roth (Lowes) 52" with remote. I'm really not interested in the remote, so I connected it to the existing fan/light wall control. I have a similar fan with a remote, and slow is not quite as slow as I would like for just moving air. I don't see much benefit with the remote since I am already wired for dual control, and I'm sure the remote will always be on the opposite side of the room when I am laying on the couch, assuming the dog does not chew it up by the end of the week.
The light is dimming fine, but I seem to have no speed control on the fan - high speed only. I'm guessing a shorted triac in the fan control.
The manual makes no mention of using a speed controller, other than in "troubleshooting" where it is not recommended to use a solid state control because it may cause noise/hum. The old fan would hum at low speeds, so I usually left the control at max and used the pull chain to vary speed. It is possible the wall control has been shorted for years and I never noticed. Picture attached in case anyone recognizes the old control, if it matters.
Is it possible that a modern fan would blow an old control? Any recommendations on a replacement wall control that can share a dual gang box with a regular light switch?
Also, any issue with using the remote with the old Hunter fan? (Assuming I can fit the receiver in the canopy).
tev9999 is offline   Reply With Quote
Old 12-03-2012, 11:01 PM   #2
Electrical Contractor
kbsparky's Avatar
Fan Speed Control
I use LuTron Skylark controls for paddle fans:
-KB
Old 12-03-2012, 11:47 PM   #3
Fan Speed Control
So it looks like I need a stepped speed control instead of the infinitely variable one. Is it OK to use a four speed controller (like this one) if the remote only has three? I usually run this fan 24/7 to keep heat/AC circulating and like a low speed. With my other fan low is still too fast for the winter as it causes a noticeable draft (blowing towards the ceiling), but that is also a much smaller room with the same size 52" fan.
Old 12-04-2012, 12:28 AM   #4
kbsparky's Avatar
Fan Speed Control
3-speed, 4-speed .... Either one should work fine.
-KB
Lennox Fan - Low Speed Only? Bob01 HVAC 11 07-07-2012 01:35 AM
Adding a Fourth, Lower Speed to Fan ElleNavorski HVAC 0 05-27-2012 02:19 PM
wiring for two speed Emerson motor PerryupNorth Electrical 2 12-02-2011 11:44 AM
Variable speed pumps and cycle control valves NHMaster Plumbing 0 02-25-2010 06:55 PM
Trane XV80 - low speed fan not working oregondean HVAC 4 01-12-2009 01:46 PM
