Fan Speed - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 03:08 PM   #1
fan speed
I think my fan is too noisy I have been told that it can be adjusted without loosing efficiency of the heater
Jack Matthews is offline   Reply With Quote
Old 08-08-2011, 03:13 PM   #2
Experienced
Jackofall1's Avatar
Welcome Jack, to the best darn DIY"r site on the web.
Is the fan noisy or the air coming out of the vents?
Generally air noise is caused by undersized ducting, slowing down the fan will also reduce the amount of air being circulated, less air may cause Acoil freezing and in the heating season high temp trips.
To slow the fan down you would need to know whether you have a multi-speed motor.
If you do have a multi-speed motor then wires could be changed to run at a lower RPM.
Mark
Lennox Fan - Low Speed Only? Bob01 HVAC 11 07-07-2012 12:35 AM
Variable Speed Vs " Multi - Speed " alecmcmahon HVAC 15 04-14-2011 03:06 PM
how to build a single phase induction motor sashman Electrical 3 03-31-2011 07:18 AM
changing speed of grinder MeanGene Electrical 2 03-19-2011 09:53 AM
Two Speed Compressors rjordan392 HVAC 2 08-26-2007 01:32 AM
