Old 12-20-2008, 09:31 PM   #1
Fan resets after light switch is toggled
Hi, I personally installed a fan in our bedroom with a remote. It is wired to a regular flip switch. The remote works great when the switch is on, but when we turn it off everything is reset. For example, we turn the fan and light on, then turn the switch off and back on, and the fan and light do not come back on. So, the settings are not persistent. This is a pain when we walk into the room and the remote is not handy, we are not able to turn the light on until we find the remote. Did I wire it wrong, or do we need a different switch? Thanks for any help!
texashomeowner123 is offline   Reply With Quote
Old 12-20-2008, 10:04 PM   #2
Electrical Contractor
kbsparky's Avatar
You need a new remote receiver
Those things are not supposed to "forget" the previous settings when you use the wall switch like that.
Take it back and demand a new one.
Old 12-21-2008, 11:19 AM   #3
J. V.'s Avatar
The subject of using wall switches with remote controlled fans has been discussed several times in another forum. Most agree the switch is required as a disconnecting means. Some say no switch is required, just the remote.
I can say personally, that if I turn off the switch to the remote controlled fan, it works just like it should when I turn the switch back on. I agree that you should get a replacement receiver.
Ps....The fan pull chain must be on high and the light turned on always.
Old 12-21-2008, 12:42 PM   #4
It was a dark and stormy
Yoyizit's Avatar
Volatile memory, as opposed to non-volatile memory. You need to leave the switch on.
Some devices handle this by having a keep-alive battery inside.
Same with a car radio; they have a power lead that goes downstream of the ignition switch and another that goes upstream of the ignition switch that is always powered and keeps the station memory alive. It draws a few mA, always.
Old 12-21-2008, 03:00 PM   #5
I was just going to make the same point. Are you sure there isn't supposed to be a small battery in the receiver?
KE2KB is offline   Reply With Quote
Old 12-21-2008, 05:14 PM   #6
kbsparky's Avatar
None of the receivers I have dealt with had any sort of battery in `em.
It's supposed to have a flash memory chip that helps it to "remember" the last settings used.
Old 12-21-2008, 05:19 PM   #7
OK. I guess I'm a little out-dated. Most of those types moved away from the battery a while ago.
Old 12-21-2008, 06:00 PM   #8
Yoyizit's Avatar
Non volatile memory.
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
no power going to the light switch baseballfan Electrical 18 09-08-2008 06:35 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
