Fan To Light Three Way Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 03:39 PM   #1
Question
Fan to light three way problem
Hi,
I just removed a fan and want to install a light.
It is on a three way and fan control.
Out of the box was a green, red, black and white.
I tried to set it up but each switch cancels the other out.
The light has two wires and aground. How do I do this?
Thanks,
MrPenguin
mrpenguin is offline   Reply With Quote
Old 01-08-2011, 05:02 PM   #2
Rewards Points: 6,652
Need to pull the wall plate for the switch, and find out if Red or Black comes from the light switch. 14/3 & 12/3 is used for Ceiling fans and bathroom vent with light fans, so that you do not have to pull two romex's. The light switch is not a 3-way, unless you have another switch that also controls the light only on the fan.
Old 01-08-2011, 05:17 PM   #3
joed's Avatar
Rewards Points: 13,278
The wire that was connected to the fan black should be capped.
The wire that was connected to the fan blue should be connected to the new fixture black.
the whites all connected and green and bares connect.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
light fixture removal problem rpavlick Electrical 5 11-19-2009 04:40 PM
Another motion sensing light problem Steelhead Electrical 6 12-24-2008 09:50 AM
Weird Problem with new light.... MRTOWNDRO Electrical 8 12-21-2008 04:00 PM
