Fan/Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 05:28 PM   #1
Rewards Points: 12
Fan/Light switch
Hi all, I'm new to the forum and pretty much useless when it comes to home repair. I am, however, installing a new single pole switch to control a fan/light. I've done this before in a previous house and had it working swimmingly well. However, there seems to be more wires than I remember from doing this before and I dont want to make a mistake.
its a lutron controller with a fan and light switch separate. it has green, black, red and yellow wires. the red is supposed to control the light, yellow the fan. The problem is the wiring doesnt identify itself in anyway.
here is what i did and what happens:
- green wire is connected to the ground
- red to red
- black from the control is connected to 2 black wires from the bottom of the box that were previously taped together [so 3 black wires together]
- yellow is connected to a different black wire coming from the top of the box.
this obviously isn't right since the light switch [not the fan switch] is now controlling both the light and the fan. it seems the 2 black wires from the bottom of the box could control the light and the fan, i dont know which. also, the instructions say black should connect to black, however the red wire on the control is for the light. im stumped.
any ideas? and remember, I'm a novice.
thanks
ibweis is offline   Reply With Quote
Old 01-20-2010, 07:46 PM   #2
Electrical Contractor
kbsparky's Avatar
Sounds like the connections at the fan need to be evaluated and corrected.
You will have to remove the canopy cover at the fan, and see how the wires are connected there. Chances are, both the fan and light are connected together on the red wire, and nothing is on the black wire.
-KB
Old 01-21-2010, 06:54 AM   #3
I think, too, that you may need to invest in a volt/ohm meter, if you haven't already. I think you are going to have to identify which wires have voltages.
Out of curiousity, what kind of switch was there before, and do you recall how it was wired? Are there any white wires in your box?
My best guess is that the black wire from the top of the box is your supply, and the two black wires taped together supply the fan, and the light. I am a little puzzled by the red wire. But....this is just a guess. Check things out, as Kbsparky says.
oberkc is offline   Reply With Quote
Old 01-21-2010, 08:53 AM   #4
joed's Avatar
Rewards Points: 12,028
Did you have two switches controling the fan previously? Sounds like the fan and light were both contralled by the same switch. Describe the previous setup.
Hunter Fan/light and dual switch wiring nashua Electrical 2 01-02-2010 11:40 AM
Wiring Double Switch fan/light mjbcable Electrical 5 10-18-2009 07:56 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
