Fan And Light On 14/2 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2010, 12:17 AM   #1
Fan and Light on 14/2 Wire
Need some help wiring a ceiling fan with light fixture to two switches; dimmer for light and on/off switch for fan.
I have a 14/2 wire (Black, White & Ground) coming from the ceiling and a Black, White, BLUE and Ground from the fan. How do I install the fan and Light so that i can control light with one switch and fan with the other?
THanks for your help.
Train is offline   Reply With Quote
Old 07-04-2010, 12:57 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do you mean coming from the ceiling to the switch?
You don't have enough wires from the switch to the light. You need a switch leg for the fan and a switch leg for the light. If the hot from from the panel feeds to the switch box, you also need a neutral along with those two switch legs. If the hot from the panel feeds to the fixture mounting box, you need another conductor to carry the hot from the fan box to the switch box.
Old 07-04-2010, 06:50 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Sorry, it can't be done.
Exactly what Nap said. You need a "3-wire" from the switch to the fan.
This is pretty typical in newer homes. I haven't run a 2-wire to a ceiling box in years.
Old 07-04-2010, 07:25 AM   #4
Rewards Points: 1,192
You can get a remote fan kit which will do this.Fits in fan canopy with remote control.
bobelectric is offline   Reply With Quote
Old 07-04-2010, 08:40 AM   #5
Just call me Andrew
Rewards Points: 1,020
http://www.homedepot.com/Electrical-...atalogId=10053
That will let you do what you want with only two wires. It's a wired-in switch with a fan canopy module. I installed a new fan for my brother...we ran 3-wire cable and only ended up needing 2 wires.
Andrew
secutanudu is offline   Reply With Quote
Old 07-04-2010, 08:56 AM   #6
You guys are right, I should have suggested this.
This happens a lot. So many fans come with these things included these days.
Old 07-04-2010, 10:06 AM   #7
I always run a 3-wire feed to an overhead fan
May not need it, wife only wants a fan in the sunroom - no light kit
But its better to have it & not need it then need it & not have it
At present the fan in the sunroom (Temp) has a fan & a light
Old 07-04-2010, 05:22 PM   #8
Great - thanks for the replies. My home was constructed in 1980 so we have 14/2 throughout. However, in another room i did have an electrician move and rewire a fan and it seems he just ran another "2" wire and connected one to light and one to fan then bundled it together at the switch house; again one switch for light and one for fan....
It seems my best option is to run a "3" wire from switch box to fan housing - i live in arizona and it is hot at you know it...may have to be a predawn activity...
Thanks again.
Train
Old 07-06-2010, 11:50 PM   #9
Hello All -
I purchased a remote fan kit and wired up per instructions; it's pretty straightforward.
I'm having some difficulties wiring up the switches in the housing. here's what i tried.
Black from Power Source to top screw of fan switch
Black from fan switch to black of Light Dimmer
Red from Light Dimmer to bottom screw of fan switch
What am i doing wrong?
Thanks again.
Train
Old 07-06-2010, 11:54 PM   #10
nap
You talking to me?
nap's Avatar
I would have to see the wiring diagram but offhand, what I see is you are taking a controlled wire (dimmed) from the dimmer and using it on the fan.
You are going to need a hot and a neutral most likely.
