Fan Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 10:50 PM   #1
Rewards Points: 77
Fan installation
On my front porch I have a flood light that I do not use. Is there a way that I can replace that light with a fan? If so, what is the easiest way to do so. I am pretty handy, but a novice when it comes to messing with electrical.
Justins1171 is offline   Reply With Quote
Old 11-20-2011, 10:57 PM   #2
Code05's Avatar
Rewards Points: 1,104
You will probably need to replace the electrical box with a fan rated box. They make retro kits if access is limited.
Code05 is offline   Reply With Quote
Old 11-21-2011, 06:57 AM   #3
Licensed electrician
Rewards Points: 1,490
If this light also is the only source of light for the door you will need a light kit added also. Exterior doors are required to have a source of lighting.
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 11:36 AM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 05:56 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
