Fan Forced Joined With Baseboard? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 06:05 PM   #1
fan forced joined with baseboard?
Ok, another question for you folks....
Is it possible to combine a 240v fan forced heater with a 240v baseboard on the same circuit? (This is assuming 20amp 240v circuit with 12/2 wire, and 2000w + 750w = 2750w total for both heaters).
If so, can both operate using their own separate wall mounted thermostats? The baseboard would be going in a small hallway so technically it is in a separate room from the fan forced heater (hence the need for 2 separate thermostats).
DragonFire is offline   Reply With Quote
Old 12-28-2010, 07:26 PM   #2
Assuming that baseboards and fan-forced can be combined as per above.....
Can I put in a junction box to separate the 12/2, and then run 12/2 to each thermostat and heater?
Old 12-28-2010, 08:30 PM   #3
It should work. I got 11ish amps total, let me know if my math is skewed. You can do that if there isn't anything on the units that say not to, and using a junction box to make a splice is also legal. You'd need to mount another box for the new t-stat, of course.
Just out of curiosity, how hard would it be to run another wire for a separate circuit? You're going to be putting a new junction box in anyhow, and you can get a 48" flex drill from Harbor Freight for $7 to run through the wall and into the basement, if it's a first story install. Probably easier than trying it your way if it is. (Note: Harbor Freight tools are guaranteed to break, and may not last through the end of one job.)
JPraski is offline   Reply With Quote
120v baseboard joined to receptacle DragonFire Electrical 14 12-24-2010 08:54 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
Installing some baseboard across 2 different floor types? BigJohnny Building & Construction 9 08-03-2010 11:41 AM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
