-   -   fan chord broke (http://www.diychatroom.com/f18/fan-chord-broke-5044/)
IIxXoOoXxII 11-27-2006 09:44 AM
fan chord broke
simple petty thing here, fan chord is missing, it mustve broken off before we moved in, unfortunately it broke while the fan was going apparently. Is there a way of just turning off the fan without taking it apart. It's winter, and i can't turn the light on without the fan going, its either have light and be freezing or sit in the dark. Tips appreciated thank you!:thumbsup:
jwhite 11-27-2006 01:12 PM
Nope, you will have to take the fan apart and fix or disconnect the pull chain switch.
sflamedic 11-27-2006 11:38 PM
Turn off the breaker and take off the light kit and you will see the fan chord switch. See if it is a 3 or 4 wire switch and replace with the same one. Its pretty simple to do.
sedwick 11-28-2006 09:45 AM
I don't mean to hijack your tread but i have the same problem. I took it apart and the switch had come apart and kinda fried the plastic when it shorted out. I replaced the switch and it does'nt work. My question is, would it have damaged any other componets or switchs in the fan? Thanks JD.
