Fan / Baseboard Heater Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 07:20 AM   #1
Rewards Points: 51
Question
fan / baseboard heater question
Hi,
Can I put a fan forced wall insert heater on the same thermostat as a 750W baseboard heater? I'm looking at putting a Dimplex 1000W fan forced wall insert heater on the same thermostat as a 750W baseboard heater in the same room.
Thanks!
deepstuff is offline   Reply With Quote
Old 10-03-2009, 07:47 AM   #2
If it is on a 20A circuit, yes.
Old 10-03-2009, 08:00 AM   #3
Rewards Points: 51
It is a 20A circuit with a few more heaters and thermostats combinations on that circuit. Total wattage on the 20A circuit will be less than 3800Watts.
Old 10-03-2009, 08:22 AM   #4
Code05's Avatar
Rewards Points: 1,104
What is the wattage of the T-stat?
Code05 is offline   Reply With Quote
Old 10-03-2009, 12:51 PM   #5
Idiot Emeritus
Rewards Points: 1,492
Thermostats are not usually rated in watts. They're normally rated in volts and amps.
Most wall-mount heater thermostats are rated 25 amps at 120 or 240 volts.
If the thermostat is UL listed, it'll have its rating marked on it.
Rob
micromind is offline   Reply With Quote
Old 10-03-2009, 01:32 PM   #6
Rewards Points: 51
Its good for the wattage, just wanted to kanow if it was OK to mix fan forced with a basboard heater on the same thermostat?
Old 10-03-2009, 02:09 PM   #7
Idiot Emeritus
A thermostat can control any load for which it is rated. One single load or any combination of loads.
Your installation is perfectly fine.
Rob
Running lines to baseboard heater using Pex. RyanD Plumbing 5 07-05-2009 07:32 AM
Hydrosil baseboard heater CowboyAndy HVAC 1 03-25-2008 08:16 AM
Baseboard Question polar5554 Flooring 2 02-25-2008 01:08 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
