Fan In Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 05:36 PM   #1
Rewards Points: 79
Fan in attic
So I have a van in my attic that blows outside. It has a dial that you set to a certain temp. I believe it is so it doesn't get too humid in the attic. However...whatever was covering it on the outside protecting outside elements from coming in has ripped off in a storm. It is not letting water in as well as anything else that can craw through. I have attached a pic of it from the inside and will get one outside tomorrow..anyone know exactly what these are called and if I can just get a new cover for the outside
mckain87 is offline   Reply With Quote
Old 04-12-2013, 05:47 PM   #2
Licensed electrician
Rewards Points: 1,020
That is a gable vent fan.
The outside cover is provided by the gable vent itself.
Old 04-12-2013, 06:11 PM   #3
Rewards Points: 79
So how would you recommend I get a new one?
Old 04-12-2013, 06:35 PM   #4
They should be available from a place that sells siding supplies.
Old 04-12-2013, 06:37 PM   #5
Rewards Points: 79
Awesome! Do you think like a lowes or home depot would have it?
Old 04-12-2013, 06:52 PM   #6
I would think so.
Old 04-12-2013, 08:25 PM   #7
Rewards Points: 12,830
Where is it mounted? On the roof or on the end of the house?
Sure looks like a roof vent to me not a gable vent.
There's a couple houndred post on here about how usless they are and how much better a ridge vent instead is.
That Type vent exhost the air in a circle and most of the hot moist air stays traped in the rafter bays.
Really need soffit vents also.
Got a picture of the home you can post?
Adding your location to your profile would be a huge help.
Just go to Quick links to edit.
Old 04-12-2013, 08:31 PM   #8
Rewards Points: 79
It is mounted in the ceiling and I do have soffit vents. I just need to get it covered up for now and will look at changing now..
Old 04-12-2013, 08:37 PM   #9
Ceiling
I sure hope you mean roof.
Not once have I see where you can buy just the cover.
Removing it, patching the roof and adding a ridge vent is the way I would do it.
If you insist on just replacing it any box store or lumber yards going to have them. Just going to know what size it is. Measure what size holes in the roof.
I've never seen a siding company carry them.
Old 04-12-2013, 10:13 PM   #10
Good catch Joe.
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 03:26 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-05-2011 12:17 AM
Can I mount a window A/C into the wall, exhausting to the attic? Greg2230 HVAC 2 06-01-2010 09:56 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
