Fake Ground At Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 12:19 PM   #1
Rewards Points: 87
Fake Ground at Panel
My panel has a arrmor protected ground wire run to the water lines. There is a similar jumper around the water meter. The existing line to the street is steel, but needs to be upgraded due to much corrosion.
The person who put in the breaker panel for the previous owner made a "fake" ground connection. It consisted of about 8 inches of ground rod, appropriately smashed and dented up on the top as if it had actually be driven into the ground. This he dropped into a whole in the floor which isn't even drilled all the way through the floor slab. It was held in the hole with some sort of putty or caulking type stuff. I guess it tricked the inspector, who gave the whole job an "Accepted" ticket.
I realize that I need a ground rod to supplement the water-pipe ground -- especially once the water main is changed. How and where should I install the new ground rod? Should I just try to drill all the way through the slab (and also part of the footer below it) where the "fake" ground was located, or should I start with a fresh hole through the basement floor below the electric box? The meter is inside adjacent to the breaker box. Will I need a second real ground round once the water line is changed.
Perry401 is offline   Reply With Quote
Old 05-23-2011, 12:29 PM   #2
Licensed electrician
Rewards Points: 1,028
Why not try to drive the two rods outside? More room to work and no possiblity of ground water coming up thru the slab.
MTN REMODEL LLC (05-21-2013)
Old 05-23-2011, 02:11 PM   #3
Rewards Points: 87
I was thinking this would be a lot easier. If I do this, how do I run the ground wire back into the house, and if I use 2 ground rods, do I need to run 2 wires through the walls, or can the rods be daisy chained together?
I have never seen this done, but could a ground rod (or rods) be driven horizontally through the foundation wall? I know that ground rods are sometimes laid in trenches made for this purpose.
(Sorry for not looking this up myself, but I seem to have lost my NEC books in the recent move!)
Old 05-23-2011, 02:34 PM   #4
wareagle's Avatar
You only need 1 run of conductor from the panel to the first gnd rod. Connect the 2 outside rods together. You can use the same conductor to
connect to the 2nd rod.
wareagle is offline   Reply With Quote
Old 05-23-2011, 02:36 PM   #5
You only need to drill a 3/8" hole thru the foundation for the ground wire.
Old 05-23-2011, 02:37 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
I'd run a #6 copper (bare or green) from the panel, outside to the first ground rod, then unbroken over to the 2nd rod. The run of wire from the panel to the first rod has to be unspliced though. You can terminate at the first rod, cut the wire, use a 2nd clamp on the first rod and a 3rd on the second rod if you wish. Only one wire needs to leave the panel. I wouldn't drill through the wall or the floor...what a pain. I could have both rods in and wired before drilling a hole in the wall and then driving a rod sideways.
Kyle
Old 05-23-2011, 04:16 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,858
This might be unpopular advice, but if it were my house I wouldn't do anything. Having some type of functional earth ground is important, but it's not as important as many people seem to think. Your incoming water line is much more effective as an earth connection than any ground rod could be. Unless it gets replaced with plastic, I would be perfectly satisfied with it alone.
mpoulton is offline   Reply With Quote
Old 05-23-2011, 04:35 PM   #8
Mad Scientist
I think that's exactly his problem; that his incoming water line is soon to be replaced, and it'll likely be plastic. True, the earth ground is largely unimportant for the normal functioning of the system. But one direct or close lightning strike will demonstrate the purpose of the earth ground quite handily.
McSteve is offline   Reply With Quote
Old 05-23-2011, 05:11 PM   #9
Well I certainly wouldn't go without an earth connection! However, supplementing the existing connections seems unnecessary.
Old 05-24-2011, 10:26 AM   #10
Rewards Points: 87
Wouldn't the size of the conductor be dictacted by the size of the service? I have plenty of #6 green left over from an industrial panel job, but thought I needed to use #4 as a ground. (Again, I must appologize for loosing my NEC book in the move!)
Old 05-24-2011, 10:34 AM   #11
Rewards Points: 87
Should this hole be above grade, or should it be put lower? There is a flower garden immediately outside where the ground rods would be placed. On the one hand, having the ground and wiring low would be better looking (as far as the garden goes). On the other hand, I would worry about someone with a roto tiller hitting the ground rods or wires if they are not exposed! Also, how far apart should the ground rods be driven?
Best advice would again be appreciated!
PS -- I think maybe I can plant a few bushs in the garden to hide the ground rods and wiring.
Old 05-24-2011, 10:39 AM   #12
Electrician
SD515's Avatar
Rewards Points: 504
#6 copper is the maximum required when it's connected to a rod.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Philly Master (05-22-2013)
Old 05-24-2011, 03:08 PM   #13
Rewards Points: 1,002
That is an incredibly irresponsible statement, whatever it's intended context
Anti-wingnut is offline   Reply With Quote
Old 05-24-2011, 03:45 PM   #14
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
I think the point of two grounds is that if one is being worked on there is still one that is active. If there was a fault and the ground was carrying curent, someone changing a pipe or something would get a nasty shock.
Old 05-24-2011, 05:46 PM   #15
Please do elaborate. I stand by it. The earth ground connection serves only two purposes: it stabilizes the system voltage compared to ground (draining any current capacitively coupled from primary to secondary in the utility's transformer), and it provides some slight degree of protection from nearby lightning strikes, again by ensuring the system voltage stays relatively close to the local ground potential. Since utility transformers are grounded at the pole and are also bonded to the utility neutral which is grounded at regular intervals, your own ground rod is already redundant several times over.
Just to be clear, the grounding electrode plays no role whatsoever in clearing faults or protecting people from shocks due to ground faults.
As further evidence of the relative unimportance of the grounding electrode, consider what the NEC requires: If the first ground rod has an impedance greater than 25 ohms, you have to drive a second one - no need for any further testing, or to achieve any specific impedance. Thus, if the first rod is in dry rock and has an impedance of 10,000 ohms and the second one does too, then you have a perfectly code compliant grounding system with an utterly useless impedance of 5000 ohms. And that's OK. Because it doesn't really matter much.
The Following User Says Thank You to mpoulton For This Useful Post:
brric (05-25-2013)
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Service panel ground downunder Electrical 13 05-13-2011 05:46 PM
Sub Panel Ground and Neutral COLDIRON Electrical 6 01-08-2011 11:49 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
