Old 12-06-2006, 03:25 PM   #1
faithoffroad
I don't know if you get flamed around here for newbie questions but here it goes.
I would like to run another 220 AC window unit in my house and I have run out of room in my breaker box. Can I split one of my 220 wires and run both off one breaker? If not can I split it and then just run one at a time?
faithoffroad is offline   Reply With Quote
Old 12-06-2006, 03:35 PM   #2
faithoffroad
It all depends on Amps... if you have 40A breaker and the unit only use xyz A and you have 40 - xyz left... for another unit ... if it is sufficient then you can split...
the second option is not allowed and dangers if it is overloaded as human errors can cause breaker to trip
if overloaded, installing subpanel is another option.
but this is only considered from the mathematic point of view.
for code limitation, I do not know...
KUIPORNG is offline   Reply With Quote
Old 12-06-2006, 03:50 PM   #3
faithoffroad
I realize this would not be to code. I guess in my way of thinking if you can split a 110 why cant you split a 220. Or maybe I'm wording it wrong. I'm wanting to run two legs off one breaker.
"if you have 40A breaker and the unit only use xyz A and you have 40 - xyz left... "
can you explain this more? My brain won't understand it
Old 12-06-2006, 07:27 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
faithoffroad
You can certainly legally split a 220v receptacle. The question is would you want to.
For instance, a 20 amp, 240v circuit for an A/C will likely handle a big A/C, but not two. At the same time, you cannot split a 40 amp 240v circuit into two 20 amp.
Old 12-06-2006, 10:11 PM   #5
faithoffroad
If your panel supports it you can install what I have always called a "quad" (for 220v) breaker. Don't know the real name of them. It's two breakers that fit in the place of one breaker. They are fairly expensive. That overcomes the physical space limit you are up against if your panel will accept it.
You still don't want to go over the capacity of your panel by "calculated load" amps.
geeyathink is offline   Reply With Quote
Old 12-07-2006, 07:20 AM   #6
faithoffroad
Originally Posted by geeyathink View Post
If your panel supports it you can install what I have always called a "quad" (for 220v) breaker. ........ It's two breakers that fit in the place of one breaker.
What you describe is a "twin" or "tandem" breaker. Two of them tied together is called a "quad".
Old 12-07-2006, 07:54 AM   #7
faithoffroad
I am from Hong Kong. Over there they have air conditioner on every room due to hot weather.... I don't think they install each on a separate breaker... I wouldn't think a window air conditioner would be a heavy duty machine comparing to central air conditioner... so I would think spliting the wire into multiple units should be ok as long as the total maximum amps sum of all units < the breaker's value...
I would think a window air conditioner is about equivalent usage as a portable humidifier...
