Failed Electrical Inspection In Ohio ?'s - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 02:44 PM   #1
Failed Electrical Inspection in Ohio ?'s
So I bought this property to rehab and had to get an elctrical inspection and failed. It had the copper stolen from main water line coming in wall. So theres no water meter or anything. So my question is to see if anyone can just give me a short explanation of problems I'm looking at. Here are the inspectors notes.
meter socket not attached to building
no GEC connection to water
corrosion on service connections
breakers in restricted area of panel (split buss)
etc needs new service and ec w/permit
This house is only 1000 sq ft. Thanks for any help
trubliever82 is offline   Reply With Quote
Old 01-19-2012, 02:49 PM   #2
pictures will be a big help.
Hardway is offline   Reply With Quote
Old 01-19-2012, 02:50 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Well seems pretty self explainatory (spell check! )
You need a new electrical service and need to replumb the house.
Im not sure about your local plumbing codes but if you replumb it in copper you should be able to ground the panel to the water service coming into house before meter,then ground the outside meter socket through a ground rod .
If you use a plastic water service youll need 2 ground rods outside bonded to meter socket
plummen is offline   Reply With Quote
Old 01-19-2012, 02:56 PM   #4
Ok thanks. I dont have pictures today. I was just searching for an idea of what needed done. I knew about the ground to water line but was alittle hazy about the rest.
Old 01-19-2012, 03:07 PM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by TruBeliever
So I bought this property to rehab... It had the copper stolen from main water line...
before you buy any of that copper pipe or wire be sure the building is secure.
and even then don't bring in more than you can install each day
and then start with the SMALL wire and pipe...
move up to the bigger work as you get to the end and ready for the inspections
THEN arrange for the electric meter and panel and the water service stuff last.
The Following User Says Thank You to TarheelTerp For This Useful Post:
plummen (01-19-2012)
Old 01-19-2012, 03:13 PM   #6
Julius793's Avatar
Meter pan may be loose falling off
Corrosion on the lugs, strait forward you have to clean them up
Split buss panel may only have a max of 6 breakers at top, even if it's under 6 a load calculation must be done not to overload the se conductors
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-19-2012, 03:58 PM   #7
I'd like to see a pic of the split buss panel that he called out. Obviously you need to be able to disconnect with no more than 6 hand motions but I don't understand what the "breakers in restricted area" refers to specifically.
kwilcox is offline   Reply With Quote
Old 01-19-2012, 04:01 PM   #8
Julius793's Avatar
If a load calculation wasn't done properly then even less than 6 breakers may not be there aka restricted. But could be wrong
Old 01-19-2012, 06:13 PM   #9
Rewards Points: 1,596
IS the OP in Canada?
bob22 is offline   Reply With Quote
Electrical Inspection mike6679 Electrical 5 01-09-2010 10:35 AM
Electrical Inspector Permitting problems zedman Electrical 27 11-27-2009 11:56 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 08:46 PM
Yay! Passed my electrical inspection today! MikeinBurien Electrical 2 12-17-2005 02:32 PM
