Extra Wire In Remodel Recess Cans - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 04:04 PM   #1
Rewards Points: 278
extra wire in remodel recess cans
The recess cans come with the poke in thingy instead of the wirenut
Does it support up to 3 extra wires (4 total)?
In my configuration I wanted one in from the switch and 2 exiting to power my 2 wall sconces because too hard to run from sconce to sconce
Also those NM clamps for 1/2" knock out is it ok to put 3 pairs of 14/2 NM through it? If it would even fit?
DIYGST is offline   Reply With Quote
Old 01-08-2010, 04:29 PM   #2
Inspector/Instructor
codeone's Avatar
One brand is called a WAGO connector. It takes the place of a wirenut, since the box on the can is a listed j-box you can make splices in it using all the available open holes in the connector.
It looks similar to the attached?
codeone is offline   Reply With Quote
Old 01-08-2010, 04:33 PM   #3
codeone's Avatar
The connectors you use make a differance usually they are rated for only 2 wires per connector. there should be more than 1 opening on the j-box for connectors.
Old 01-08-2010, 04:40 PM   #4
Rewards Points: 278
That's the connector. Reason I ask about the clamps is because I only bought one, looks like I need to buy another and knock another out.
Old 01-08-2010, 04:45 PM   #5
codeone's Avatar
Yes you need another connector then you would be ok. Now some halo cans come with a place for NM(romex) to go in without a connector. Ill see if I can find a Picture.
Old 01-08-2010, 04:50 PM   #6
Rewards Points: 278
I see those clip things I think, but I don't know how to use it.
Are they just as good?
I thought it was plastic, not sure.
My can is a halo 4" remodel non IC.
Old 01-08-2010, 04:52 PM   #7
codeone's Avatar
Does it look like a black plastic slot?
Old 01-08-2010, 04:57 PM   #8
codeone's Avatar
Does it look similar to this? At least the black plastic piece.
Old 01-08-2010, 05:11 PM   #9
Rewards Points: 278
it has got the square plastic clamp near the knock out but not the thing sticking out to the right
Old 01-08-2010, 05:16 PM   #10
codeone's Avatar
Yes that is an NM cable connector you just have to figure out how to use it. Its a new style Im not familuar with.
Old 01-08-2010, 05:20 PM   #11
Rewards Points: 278
or a 89 cent NM clamp that I know how to use
Old 01-08-2010, 05:34 PM   #12
codeone's Avatar
Go get em! Youve got the right idea. Do whats easy for you.
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 08:55 AM
2 Wire Thermostat question vtec69 Electrical 19 10-19-2009 05:14 PM
How do I wire these switches? keano016 Electrical 2 10-07-2009 10:19 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
