Extra Wire To Do Pigtails For Outlet...splice Romex? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2009, 08:05 AM   #1
Rewards Points: 384
Extra wire to do pigtails for outlet...splice romex?
To install the GFI outlet I have to pigtail the white together and connect them to the terminal and same with the black but where do I get the extra little wire to go from the pigtail to the terminal? Do I just splice open a romex cable or do they sell individual red/black, white 12awg wire for this?
RyanD is offline   Reply With Quote
Old 05-12-2009, 08:44 AM   #2
Cut a piece of romex about 6" (or however) long, strip off the sheathing and voila, you have white, black and ground pigtails.
Burbman is offline   Reply With Quote
Old 05-12-2009, 10:57 AM   #3
joed's Avatar
Rewards Points: 12,028
You can usually put two wires under a screw on a GFCI. They have back wire terminals and allow a wire on each side of the screw.
Old 05-12-2009, 12:05 PM   #4
Rewards Points: 82
Correct. If there are only two wires each, no pigtailing is required.
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Want to wire extra lights to garage door opener SuperAkuma Electrical 14 08-02-2008 08:48 AM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
