Old 12-14-2010, 06:45 PM   #1
extra wire before rec box
Hey, I was called into a job to "fix" some wiring. The guy before looped the wire to the rec. prob about 10 inches before it went into the box. Im a little confused on this one, he said its required. Am I missing something or is he confused with the extra that has to be left outside the box after the wire is in.
sparky23 is offline   Reply With Quote
Old 12-14-2010, 06:49 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
If there is extra romex behind the wall going into the box, it allows for extra when you need it, in case the wire gets cut too short later on down the road. Not required, but handy with ceiling lights.
Old 12-14-2010, 07:48 PM   #3
joed's Avatar
The wire needs to be stapled within 1 foot of the box. The loop if you put on in, has to be after the staple. It is not required.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-14-2010, 07:48 PM   #4
Electrical Contractor
Not in the NEC, but some areas around here are pushing for that.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
extra wire in remodel recess cans DIYGST Electrical 11 01-08-2010 06:34 PM
What type wire to use from transfer switch to outdoor outlet brjl Electrical 7 12-02-2009 04:35 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
