Extra Light On 3 Way - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 03:32 PM   #1
extra light on 3 way
I have a 3 way switch at the top and bottom of stairs to basement. Tried to wire a light at the top of the stairs off of that 3 way but that light goes on when the other lights in the basement go off and vice versa. In the box at the top of the stairs, the red wire is connected to the neutral (white) wire coming from the lower box. ANy suggestions?
Jack
jackal1953 is offline   Reply With Quote
Old 08-04-2012, 04:12 PM   #2
"So I Re-Wired It"
MisterZ's Avatar
if you want this light to go on and off with the others, you'll need to come off the wire that feeds basement lights. (after the switch)
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-04-2012, 04:37 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by jackal1953 View Post
ANy suggestions?
Jack
its wired wrong. and as suggested, come off the existing light.
Adding GFCI and extra light EelectricP Electrical 3 08-05-2011 10:40 PM
Dual-brite motion detector light to operate second light? downunder Electrical 2 09-10-2010 03:48 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
