External Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 01:50 PM   #1
Rewards Points: 37
I want to install some lighting in my kitchen and run exposed conduit. Similar to the below picture. My question is, what goes on the other side of the junction box, the other side of the drywall that is, if anything? Does there need to be some type of box on the concealed side, or is it acceptable to drill a hole through the drywall, mount a box on the surface and pull the cable through a knockout in the back of the box, secure with a clamp, and make the connection inside the box?
RodBarney is offline   Reply With Quote
Old 01-09-2012, 01:52 PM   #2
Licensed electrician
Rewards Points: 1,598
The cable or conduit can enter the back of the circled box as long as the proper connector is used.
Be sure to bond all the metal parts.
RodBarney (01-09-2012)
Old 01-09-2012, 01:56 PM   #3
Rewards Points: 37
Thanks Jim.
Old 01-09-2012, 04:32 PM   #4
Electrician
Rewards Points: 794
Gotta to ask why you want exposed conduit in your kitchen.
darren is offline   Reply With Quote
Old 01-09-2012, 05:06 PM   #5
Rewards Points: 37
Mainly because I have an industrial style theme going on. Given that, this is an added bonus because its way easier. Dont worry it will look spectacular!
Old 01-09-2012, 05:09 PM   #6
I can see it needing constant cleaning from greasy dust buildup regardless of how clean of a cook you are.
Old 01-09-2012, 05:37 PM   #7
Electrician
Rewards Points: 794
Rod that is what I was thinking, post some pics when you get it done I would like to see it.
Old 01-09-2012, 06:10 PM   #8
Rewards Points: 37
This is true. Then again a lot of other stuff in the kitchen does too, guess I'll add it to the list.
Old 01-09-2012, 06:11 PM   #9
Rewards Points: 37
I absolutely will. Dont hold your breath though, I'm still in the early stages of the kitchen light project...
Installing Light on Round Junction Service Box MegR Electrical 7 07-07-2013 08:31 PM
Garage feeder junction box bonding WillK Electrical 0 06-05-2011 10:03 AM
grounding old 2 wire junction to grounded junction gm8075 Electrical 3 03-28-2011 11:46 AM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
