Exterior Xmas Light Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2008, 02:41 PM   #1
Exterior xmas light outlets
Hello all:
I'm in the process of building a new home in Portland OR, and could use a little wiring advice.
I would like to install outlets in the soffit under the eaves of the roof, and have a few questions/points of advice that I'm struggling with.
1. With an outlet under the eaves, do I need to have the new full plastic cover that are code for other standard exterior outlets? These outlets will be installed "upside down"... and it seems that this cover would simply hang open rather than doing it's intended job of protecting the outlet.
Or, can I use the more traditional hinged covers which snap back into position regardless of orientation?
2. Has anyone seen any "round" outlets. It would be much easier for me to drill a hole with a hole-saw... then use a round remodel gang ... rather than trying to make the exact cuts to fit a rectangle single gang box.
Thoughts?
Thanks!!
Dave
dlgobeavs is offline   Reply With Quote
Old 05-21-2008, 04:54 PM   #2
Registered User
Termite's Avatar
The soffits of your house would typically be considered a wet location, just like the ceiling of a shower. Although its not necessarily going to get rain, there's always a potential for icing, spray, etc.
There are those that would consider this a damp location.
The receptacles must be GFCI protected, and must have weatherproof covers. The bubble covers are popular, but I don't think they're supposed to be used face-down. A NEMA 3R cover would be more appropriate.
As for round receptacles, they make round boxes, but I'm not aware of any weatherproof covers in that shape. Its easy to cut a rectangle...Just use the box as a template and use a jigsaw!
Old 05-21-2008, 08:43 PM   #3
Use standard outlets and standard weatherproof cover. Not the bubble you're talking about, the hinged ones will be fine. Do not use GFCI outlets unless you have to. You'd be much better off using a 20amp GFCI breaker to keep you from dragging out that extension ladder if the damned thing trips. Also it'll be on a dedicated ciruit so you can string more lights without any problems. Pull #12/2.
Super33 is offline   Reply With Quote
Old 05-21-2008, 08:50 PM   #4
electrician
I run a switched receptacle in the soffit so you can turn the lights on and off from inside the house.
Silk is offline   Reply With Quote
Old 05-21-2008, 11:30 PM   #5
Registered User
Termite's Avatar
That's always a great feature. And it sure is smart to use GFCI breakers instead of GFCI receptacles.
Old 05-22-2008, 10:38 AM   #6
Power Gen/RS Engineer
Rewards Points: 566
Good idea. While you're up there, screw one into the chimney for the plastic Santa.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
Wall outlets stay charged even when light switch is turned off proofer Electrical 33 01-25-2008 05:43 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
