Exterior Soffit Lights On Inside Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 02:40 AM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
exterior soffit lights on inside circuit
Can exterior soffit lights be run of a inside light circuit or do they require there own circuit like outdoor receptacles? Only reason i ask is because i know any outdoor plugs require there own GFCI circuit but if any plug is more than 8' feet from the ground it can be supplied from a interior light curcuit.
Lights are 10' above ground in the soffits..
ryanh is offline   Reply With Quote
Old 06-03-2009, 05:34 AM   #2
Remodeling Contractor
They are tied in with other interior lighting circuits. Since no contact with the wet earth is a factor these are not required to be GFI protected.
Old 06-03-2009, 06:33 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Well, I don't know The Canadian code on this but our outside receptacles do not have to be fed on their own circuit.
Bob, also, even outdoor lights IN the ground do not require GFI protection. Only standard receptacles. There is no "in contact with wet earth" code.
Speedy Petey is online now   Reply With Quote
Old 06-03-2009, 11:47 AM   #4
I did not say it was code. I was adding this to add to the justification as to the logic of not needing these lights on a GFI.
20 Amp Bathroom Circuit theatretch85 Electrical 3 04-06-2009 09:33 PM
Should Ceiling lights be on separate circuit? handyoldgal Electrical 29 03-18-2009 08:54 PM
How Many Lights on a 15 amp Circuit? Bill_in_NY Electrical 22 02-20-2009 05:52 PM
Adding lights to a circuit.. Pl check circuit aw44 Electrical 4 08-27-2008 02:09 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
