Old 01-10-2012, 07:21 PM   #1
Exterior Soffit Lighting - Please Help with Light Placement
After browsing the Web and thinking about my project, I've decided to ask the user community for their opinions on lighting the exterior of my home. In particular, I am considering the installation of small, 4" canned lighting in my soffits to illuminate the red brick on my home at night. I am currently considering lighting the front and sides of the home.
Because these lights will burn for many hours each night, I would prefer to use LED bulbs, and I have found one that suits my need. It has a long life span, consumes 8 watts (produces light comparable to a 40w incandescent), has a reasonable color temperature and produces a narrow (spot) beam.
The primary issue I'm facing is determining where to install the cans in the soffit to achieve the most aesthetically-pleasing result. I've included a photo of my home so everyone can see the detail of the soffit (2nd story only) where the lights will be installed.
As I see things, I more-or-less have two options: 1) Install a can above each window; or 2) Install a can between each set of corbles, at the center point. The house is approximately 40' wide, and in either option there will be 5 lights across the front of the home.
Please let me know which option you think would be better, or if you have a different idea, I'm all ears.
I should note that there are other LED options that produce a flood beam instead of a spot beam. I'd consider using a flood bulb, too, if the community thinks that doing so would yield a better result.
Thanks for your help.
RedRX is offline   Reply With Quote
Old 01-10-2012, 07:40 PM   #2
MarginallyQualified
NO!!!!!!!!!!
Don't do it!
Or do NOTHING AT ALL!!!
Please let me know which option you think would be better NEITHER
1) Leave it the F alone.
But if you are absolutely compelled to add lighting...
2) A very small security spot or two under a porch eave. No more.
hth
TarheelTerp is online now   Reply With Quote
Tags
exterior, lighting, soffit
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 04:00 PM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 10:07 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 6 08-17-2009 08:37 PM
